saflyer Posted February 19 Share Posted February 19 My 2005 HR Ambassador manual says to use Dexron 3 transmission fluid in the leveling jacks hydraulic system. They continually upgrade these fluids over the years and are now up to Dexron 6, 3 is no longer available. Am I correct in thinking any Dexron with a number 3 or higher is OK for the hydraulic system? Also, an RV mechanic told me Mercon 5 is acceptable. Is that true? Thanks Link to comment Share on other sites More sharing options...
Oregon04Windsor Posted February 19 Share Posted February 19 (edited) I recently went down this road. Supposedly Dexron 6 is backwards compatible in transmission applications but not necessarily in hydraulic applications. I didn't want to risk it and found that Dexron III is still readily available at most parts houses and tractor supply companies. I found mine at Carquest for $80/5 gal of Dexron III/Mercon. Walmart also carries Dexron III in gallon jugs. Edited February 19 by Oregon04Windsor 1 Link to comment Share on other sites More sharing options...
saflyer Posted February 19 Author Share Posted February 19 (edited) Thanks, I’ll look around. Interesting thing I noticed shopping for Dexron 3 on Amazon. Some of the brands just say Dex/Merc. Probably the latest spec but not sure. Might say in the fine print of the label what the number is. Edited February 19 by saflyer Link to comment Share on other sites More sharing options...
vito.a Posted February 19 Share Posted February 19 I used Valvoline Dex/Merc. Valvoline DEX/MERC Automatic Transmission Fluid (ATF) 1 GA - Walmart.com Recommended for use in the following applications: MERCON*, DEXRON*-III, Ford M2C138-CJ and M2C166-H, Allison C-4 and TES-389, and Caterpillar TO-2. Formulated with premium base stocks and advanced additive technology to meet the challenging demands of automatic transmissions Engineered with a proprietary blend of base oils and advanced additives to provide better oil flow at low temperatures and greater film protection at higher temperatures Formulated with advanced additives to resist fluid breakdown and thickening at high temperatures Flows easily at low temperatures providing good cold-start shifting Greater friction stability to help maintain consistent shift performance Enhanced anti-shudder protection for smooth shifting and maximum power transfer Developed with anti-wear technology to help improve transmission durability Minimizes sludge and varnish deposits For use where DEXRON*-III or a MERCON* fluid is specified If you want synthetic, then this will work: Valvoline MaxLife Multi-Vehicle Full Synthetic Automatic Transmission Fluid (ATF) 1 GA - Walmart.com Link to comment Share on other sites More sharing options...
Calvin Morse Posted February 19 Share Posted February 19 I contacted "Bob The Oil Guy" Regarding Dextron III . He said to use Transynd TES-295 in my Nelson Hydraulic Reservoir to add or replace Dextron III. Its a TES-295 synthetic transmission fluid and It's fully compatible. You can also mix it with the existing Dextron III if just topping off. Link to comment Share on other sites More sharing options...
Fasthobie16 Posted February 19 Share Posted February 19 What Vito says. Valvoline ATF Dex/Merc .Recommend for the Liberty trans too Jim 2000 Dynasty/ 2004 Liberty Toad Link to comment Share on other sites More sharing options...
saflyer Posted February 21 Author Share Posted February 21 Thanks, I’ll look around for the Valvoline Dex/Merc. I think I saw the same label on a Fram bottle. I’ll read the fine print. Link to comment Share on other sites More sharing options...
saflyer Posted February 22 Author Share Posted February 22 9 hours ago, saflyer said: Thanks, I’ll look around for the Valvoline Dex/Merc. I think I saw the same label on a Fram bottle. I’ll read the fine print. I found a qt. of Ace brand at Ace Hardware. Label says Dexron-3/Mercon. Going to use it. Link to comment Share on other sites More sharing options...
96 EVO Posted February 22 Share Posted February 22 On 2/19/2022 at 10:14 AM, Calvin Morse said: I contacted "Bob The Oil Guy" Regarding Dextron III . He said to use Transynd TES-295 in my Nelson Hydraulic Reservoir to add or replace Dextron III. Its a TES-295 synthetic transmission fluid and It's fully compatible. You can also mix it with the existing Dextron III if just topping off. That's pricey fluid to use in a simple hydraulic system! Link to comment Share on other sites More sharing options...
Calvin Morse Posted February 22 Share Posted February 22 I agree. I had extra. My understanding is that Monaco eventually went to synthetic. Link to comment Share on other sites More sharing options...
