bradc344 Posted February 21 Share Posted February 21 Hi, I have 2008 Holiday Rambler Neptune and around 40-48 mph I have a wind noise and cant figure it out any ideas? All the window have weep hole cover ,I put foam into the rails for the awing , it seems to be coming from the passenger side the door seems to be closed tight . thanks for any information Link to comment Share on other sites More sharing options...
Jdw12345 Posted February 21 Share Posted February 21 Maybe from the windshield seal…… Link to comment Share on other sites More sharing options...
Rodger Posted February 21 Share Posted February 21 The foam in the awning is a typical source, as you must already be aware since you have done that. Did you run it the full length? Link to comment Share on other sites More sharing options...
bradc344 Posted February 21 Author Share Posted February 21 I thought that but I just had the windshield replaced and it does it with the new windshield also same speed same noise level thanks Link to comment Share on other sites More sharing options...
Joel & Susanna Posted February 21 Share Posted February 21 Indeed I had the same noise but we filled the awning supports over the door completely and the whistle went bye bye! Link to comment Share on other sites More sharing options...
bradc344 Posted February 21 Author Share Posted February 21 Joel & Susana what did you fill them with I used solid foam maybe need to redo it thanks Link to comment Share on other sites More sharing options...
Paul A. Posted February 21 Share Posted February 21 Use 12" strips of duct tape and place around the edge of the windshield and the leading edge of the coach entrance door. Remove 1 at a time and you will find the wind noise location. Clearance lights are a known problem too. Link to comment Share on other sites More sharing options...
Tom Whitlow Posted February 21 Share Posted February 21 I believe there's a small hole/crack in the pressurized door seal on our coach. Lazydays (Tampa) is supposed to fix it. If I EVER get it back from them, I'll know more. Link to comment Share on other sites More sharing options...
Joel & Susanna Posted February 21 Share Posted February 21 Lol, I went to Lowe’s and bought foam insulation for water pipes, shoved it in ! 1 Link to comment Share on other sites More sharing options...
DrDon4u Posted February 21 Share Posted February 21 Get some water hose or some kind of hose, put one end by your ear, walk around near the noise and see if it gets loader until you find where it's coming from. Link to comment Share on other sites More sharing options...
bradc344 Posted February 21 Author Share Posted February 21 great idea thanks Link to comment Share on other sites More sharing options...
Tom Whitlow Posted February 22 Share Posted February 22 Wait a minute. I thought the noise was while driving? Link to comment Share on other sites More sharing options...
tomevansfl Posted February 23 Share Posted February 23 On 2/21/2022 at 1:22 PM, Tom Whitlow said: I believe there's a small hole/crack in the pressurized door seal on our coach. Lazydays (Tampa) is supposed to fix it. If I EVER get it back from them, I'll know more. Good luck with Lazy Days in Tampa. I have heard many people that have had poor luck with them. I’ve heard many say they gave good service. However, I’ve never used them so I have no experience with them. I live in Orlando so they’re too far away. Link to comment Share on other sites More sharing options...
Tom Whitlow Posted February 24 Share Posted February 24 7 hours ago, tomevansfl said: Good luck with Lazy Days in Tampa. I have heard many people that have had poor luck with them. I’ve heard many say they gave good service. However, I’ve never used them so I have no experience with them. I live in Orlando so they’re too far away. There's not a lot of places that work on things like slideouts and major electrical problems. Lazydays is actually in Seffner right off I-4. Where do you take your coach for big repairs? Link to comment Share on other sites More sharing options...
daveyjo Posted February 25 Share Posted February 25 I put foam from swimming pool noodles over the support struts and the noise went away! Link to comment Share on other sites More sharing options...
RoadTripper2084 Posted February 25 Share Posted February 25 9 hours ago, daveyjo said: I put foam from swimming pool noodles over the support struts and the noise went away! Could you post a picture? you mean you put foam around the front-facing edges of the door awning arms? Link to comment Share on other sites More sharing options...
Ray Davis Posted February 25 Share Posted February 25 My 03 Windsor had foam inside the arms for the door awning, but I never thought about why until one day a noise started that caused me to look toward the right mirror where I saw the foam blow away. At about 60 mph the noise, really an unbearable howl, just about ran us crazy before I stopped and bought some pipe foam and stuffed it in the awning arm. Peace at last, the noise was gone. Link to comment Share on other sites More sharing options...
daveyjo Posted February 25 Share Posted February 25 31 minutes ago, RoadTripper2084 said: Could you post a picture? you mean you put foam around the front-facing edges of the door awning arms? I'm sorry. I put it inside the post. T'was a long time ago. Link to comment Share on other sites More sharing options...
Joel & Susanna Posted February 26 Share Posted February 26 On 2/21/2022 at 10:45 AM, bradc344 said: Joel & Susana what did you fill them with I used solid foam maybe need to redo it thanks I put the foam tube (pipe insulation) inside (backside) of the door awning supports. Indeed the howl was pretty loud but it certainly worked as a speed warning! Cheap fix. Link to comment Share on other sites More sharing options...
bradc344 Posted February 26 Author Share Posted February 26 thank\k you fr\or all the suggestion Brad Link to comment Share on other sites More sharing options...
