kenandjoanne2002 Posted February 25 Share Posted February 25 I have a 02 Diplomat with the original Jensen b/w rear camera. I want to update to colored but use the same cables. #1 has anybody done that? Were the wiring similar? Did you need a professional electrocution? Are some newer colored units better than others? My camera pin has 6 pins and power connection has 3. Ken Parsons 02 Monaco Diplomat pbdd Link to comment Share on other sites More sharing options...
Dwight Lindsey Posted February 25 Share Posted February 25 Call RVCAMS: www.rvcams.com Tell them what you have and what you'd like to do. They are very helpful. Dwight Link to comment Share on other sites More sharing options...
gdroberson Posted February 25 Share Posted February 25 that is where I got mine from fit right in the place of the old one just could not use the camera cover on the back Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted February 25 Share Posted February 25 1 hour ago, kenandjoanne2002 said: I have a 02 Diplomat with the original Jensen b/w rear camera. I want to update to colored but use the same cables. #1 has anybody done that? Were the wiring similar? Did you need a professional electrocution? Are some newer colored units better than others? My camera pin has 6 pins and power connection has 3. Ken Parsons 02 Monaco Diplomat pbdd Electrocution? No , the wires do not carry enough voltage to get electrocuted? Chuck B 2004 Windsor 1 Link to comment Share on other sites More sharing options...
Old Dog Posted February 25 Share Posted February 25 Rvcams has an adapter that splices onto existing camera cable. They are very helpful, I used there expertise to install side view cams with a controller all wired to turn signal triggers etc. Made a big difference in visibility. Not cheap but nothing is these days. Link to comment Share on other sites More sharing options...
woodylmiller Posted March 6 Share Posted March 6 You can reuse the existing wiring, I did. Just match the colors on each end. No problem. I soldered my connectors to the old wire, but there are some kits out there for adaptors so you don't have to solder. Woody Miller 09 Dynasty Link to comment Share on other sites More sharing options...
