Hancoman Posted February 26 Share Posted February 26 Hi All Heading down to Arizona for 5 weeks or so. Second day out, wife was washing dishes, when she pulled the stopper to drain it sounded different, checked under the sink dry no water. I went outside and I had soapy water dripping out of 3 bays. All other sinks drain properly. Kitchen sink is in the slide out. Obviously broken drain pipe under the sink , how do you get to it ? Is it an easy fix while on the road? Thanks in advance Tom 43’ executive Link to comment Share on other sites More sharing options...
Dr4Film Posted February 26 Share Posted February 26 The leak is most likely in the drainpipe that travels with the slide in conjunction with the flex pipe that allows the drain and slide to move. Trace the drain and your find the leak. It won't be directly under the sink. Link to comment Share on other sites More sharing options...
Ivan K Posted February 26 Share Posted February 26 Number of us had this issue. Access to the hose depends on your floor plan. Look here for similarity, there is a number of posts with this subject. Broken kitchen sink drain https://www.monacoers.org/topic/3071-broken-kitchen-sink-drain/ Link to comment Share on other sites More sharing options...
vito.a Posted February 26 Share Posted February 26 This is a link to a great thread with pictures on repairing the slide out drain hose. Kitchen sink flexible drain hose replacement - iRV2 Forums Link to comment Share on other sites More sharing options...
engine103 Posted February 26 Share Posted February 26 A timely article. Mine just started leaking and dripping on the inverter. For now I have been covering the inverter with a large plastic bag to keep the water off until I can find the leak. Ivan, I'm assuming that our layout would be the same so I will check under the bath sink. Jim Link to comment Share on other sites More sharing options...
Ivan K Posted February 26 Share Posted February 26 11 hours ago, engine103 said: A timely article. Mine just started leaking and dripping on the inverter. For now I have been covering the inverter with a large plastic bag to keep the water off until I can find the leak. Ivan, I'm assuming that our layout would be the same so I will check under the bath sink. Jim Jim, yes, my access was through false wall behind the sink cabinet in the bathroom and also could see the hose from the hallway through the little door against fridge. Link to comment Share on other sites More sharing options...
BillDeb45 Posted February 26 Share Posted February 26 I had same problem. I had to cut the false wall with a reciprocal saw to be be to access the pipe. The flexible white hose had come loose from the hard plastic pipe. I used a repair piece from Home Depot. It has tightening bands on both ends. Mine for some crazy reason had carpet under the plywood. I had to cut what I could so I could pull out the soaked carpet and pad. I then ran a fan inside the opening to dry out what I could not remove Link to comment Share on other sites More sharing options...
BillDeb45 Posted February 26 Share Posted February 26 Link to comment Share on other sites More sharing options...
Jerry G Posted February 26 Share Posted February 26 Just went through this last week. Have an 01 Dynasty. If yours is the same. Access is behind "accordian" panel. pic is upside down sorry. Under sink you must remove floor, which just lifts out. Then note screws on the left panel. 4 must be removed. Look in with a flashlight and you should see a small braided wire. Unhook it and the panel will roll open. Pipes are accessible from there. Mine was broken right at top connector. Thought ok just reconnect. It will only be an inch shorter. My bad. Reconnect. Done. Three times in and out with slide...leaking again. The 20 year old pipe cracked at the bend. Had to go back In and replace entire pipe along with both connections which broke while taking it apart. Link to comment Share on other sites More sharing options...
Hancoman Posted February 27 Author Share Posted February 27 That looks easy but my accordion panel-is only quarter exposed when my slide is out. Pulled a panel under the bathroom sink couldn’t see anything there probably in the cupboard next to the sink. I have a bad shoulder so my maneuverability is limited but I will keep looking. Link to comment Share on other sites More sharing options...
wamcneil Posted February 27 Share Posted February 27 18 hours ago, Jerry G said: Just went through this last week. Have an 01 Dynasty. If yours is the same. Access is behind "accordian" panel. pic is upside down sorry. Under sink you must remove floor, which just lifts out. Then note screws on the left panel. 4 must be removed. Look in with a flashlight and you should see a small braided wire. Unhook it and the panel will roll open. Pipes are accessible from there. Mine was broken right at top connector. Thought ok just reconnect. It will only be an inch shorter. My bad. Reconnect. Done. Three times in and out with slide...leaking again. The 20 year old pipe cracked at the bend. Had to go back In and replace entire pipe along with both connections which broke while taking it apart. That was similar to my failure. The connection at the end of the flex pipe wasn’t secured and that caused the rigid section of pipe to move as the slide went in/out. It would up snapping near the elbow at the back of the cabinet. Had to replace most of the drain plumbing in the kitchen slideout. I hope yours winds up being an easier fix! Cheers Walter Link to comment Share on other sites More sharing options...
