Brett63 Posted February 27 Share Posted February 27 What would or could be the probable cause for the bottom 7.5a fuse located on the BIRD board in the picture labeled PCB PWR to constantly blow? We are sitting parked, plugged in to 50a power and it is blowing at least everyday. I don't sit out and stare at it but when I check on it it has blown again. Not sure why the picture posted so far below the text...Sorry Link to comment Share on other sites More sharing options...
Gary M Posted February 27 Share Posted February 27 2 minutes ago, Brett63 said: What would or could be the probable cause for the bottom 7.5a fuse located on the BIRD board in the picture labeled PCB PWR to constantly blow? We are sitting parked, plugged in to 50a power and it is blowing at least everyday. I don't sit out and stare at it but when I check on it it has blown again. \\ Not sure why the picture posted so far below the text...Sorry I am no help with your issue, but as far as the space in your post, I found if I notice the space, I go back and do a small edit and save it goes back to normal. I think Scotty was working on it but with his wife sick ( prayers) he has that as a priority. Link to comment Share on other sites More sharing options...
Brett63 Posted February 27 Author Share Posted February 27 5 minutes ago, Gary M said: I am no help with your issue, but as far as the space in your post, I found if I notice the space, I go back and do a small edit and save it goes back to normal. I think Scotty was working on it but with his wife sick ( prayers) he has that as a priority. Yea I tried that, that's why it says edit....didn't change anything...lol 1 Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted February 27 Share Posted February 27 A steady ground. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
DavidL Posted February 27 Share Posted February 27 If the fuse is blowing, than there is either a short or the circuit is drawing more current than what it is designed for. So, a bad ground, a shorted BIRD, a chafed wire to ground, etc. You need to get a schematic of that circuit and then split the circuit in "half" and measure current to ground on the fuse to isolate where the issue is. But you need the schematic so the circuit can be traced to know what is powered by that circuit. Link to comment Share on other sites More sharing options...
Ray Davis Posted February 27 Share Posted February 27 When you go to edit can't you click just above the picture and backspace the picture until it's close to the message? Link to comment Share on other sites More sharing options...
Larry Maida Posted February 27 Share Posted February 27 (edited) I was always lead to believe that if a fuse is blowing its a safety feature. The alternative is a fire. I would suggest you find the cause instead of feeding it fuses. Edited February 27 by Larry Maida Link to comment Share on other sites More sharing options...
Brett63 Posted February 27 Author Share Posted February 27 1 hour ago, Larry Maida said: I was always lead to believe that if a fuse is blowing its a safety feature. The alternative is a fire. I would suggest you find the cause instead of feeding it fuses. I have been searching for a cause for a couple days, but thanks. Link to comment Share on other sites More sharing options...
Frank McElroy Posted February 28 Share Posted February 28 Brett, in looking at the schematic I sent you for this board, it is very likely that the big boy solenoid or associated wiring is failing. Since you already have a spare big boy, I'd swap it out and see if that solves the problem. When doing the swap, look carefully at the wires going to the solenoid coil. A loose wire at the solenoid coil connection could also cause high current draw. 1 Link to comment Share on other sites More sharing options...
Ivylog Posted February 28 Share Posted February 28 (edited) It’s the BigBoy going bad. You can go to a 10 amp fuse for awhile but if you do have another BigBoy, put it in. Edited February 28 by Ivylog Link to comment Share on other sites More sharing options...
joefromperry Posted February 28 Share Posted February 28 I had the same issue with the fuse blowing on my 2003 signature. I pulled the big boy and took it apart, cleaning the corrosion, etc. It wasn't difficult to do. When I put it back together, the fuse stopped blowing. Been good for a year now. Link to comment Share on other sites More sharing options...
Ivylog Posted February 28 Share Posted February 28 14 hours ago, joefromperry said: I had the same issue with the fuse blowing on my 2003 signature. I pulled the big boy and took it apart, cleaning the corrosion, etc. It wasn't difficult to do. When I put it back together, the fuse stopped blowing. Been good for a year now. Not sure how cleaning the contacts changed the resistance of the coil that engages the contacts. Taking the small energizing wires off and back on maybe. Link to comment Share on other sites More sharing options...
