bradc344 Posted February 27 Share Posted February 27 Hi ,I just got to the camp ground and have no power to by leveling jacks been working great also when I started the trip the light on my ebrake would not go completely out the brake does release, the light just goes from bright to dim ,not sure if they are related but both happened at the same time . I think the brake is related to the leveler working ,not sure what to do ,also the fuses are good to the levelor , any Ideas Link to comment Share on other sites More sharing options...
MrAmbassador Posted February 28 Share Posted February 28 Is there a bussing alarm? The parking brake is associated with the leveling system. It is a safety that keeps the Coach from moving until the Jacks are completely up. If the air brake switch is not sending a signal that it is in applied the leveler system will not work. Hope this helps. Link to comment Share on other sites More sharing options...
bradc344 Posted February 28 Author Share Posted February 28 thanks for the information I dont have any buzzing just a bell sound 1 Link to comment Share on other sites More sharing options...
MrAmbassador Posted February 28 Share Posted February 28 Will do, I am not exactly sure where the fuse is located. However, I suspect it is in the fuse compartment located under the driver side outside compartment. The black box with 3-wing nuts. I would do a continuity check across each fuse. I am not at my coach, but if I am not mistaken the legend on the back of the cover identifies the fuse for the levelers. Link to comment Share on other sites More sharing options...
bradc344 Posted February 28 Author Share Posted February 28 the fuse looked good but will do continuity test on them thanks Link to comment Share on other sites More sharing options...
