63Hotrod Posted March 2, 2022 Posted March 2, 2022 Our 08 Endeavor has separate driver and passenger front window sun shades. The drivers side will now go down but not back up. Changes the switch and still have the problem. Does anyone know who made these or where we could get a motor or a way to repair
Guest Dive Dive Posted March 2, 2022 Posted March 2, 2022 I had to pull my passenger shade out to find out it was made by Automotion. I found a dealer in Elkhartthat sells replacement motors Bradd and Hall. However I know there are other OEMs that supplied shades to Monaco.
Tom Whitlow Posted March 2, 2022 Posted March 2, 2022 I just replaced the motor on our 09 Dynasty electric suncreen roller shade for the passenger window. I ordered the replacement motor from MCD which is somewhere in the Dallas area. Fairly easy repair. I found the company name on the old motor when I removed it. Yours may be different. Here's the MCD order form. Replacement Part-Shade Order Form 10.2019 Interactive.pdf
63Hotrod Posted March 2, 2022 Author Posted March 2, 2022 Tom how did you get it down. There are two screws on each end of the unit. But removing them had no effect it is still firmly mounted
GranPrix Posted March 2, 2022 Posted March 2, 2022 our coach has shades made by "The Right Track" in Crofton, MD. great service.
Tom Whitlow Posted March 2, 2022 Posted March 2, 2022 Just now, GranPrix said: our coach has shades made by "The Right Track" in Crofton, MD. great service. On mine they just snap into metal clamps. One toward each end. Just pull down while rotating slightly. Then unplug or undo the two wires. I'd go look at our coach but Lazydays has decided they like it so much they've kept it for going on two months now.
63Hotrod Posted March 4, 2022 Author Posted March 4, 2022 It was held by two screws at each end but had become stuck to the overhead. Got it down now looking for mfg info. Good luck at Lazydays spent a year there one week
63Hotrod Posted March 4, 2022 Author Posted March 4, 2022 Turns out this is an AutoMotion unit and the part number has faded. I called them but they were less than helpful. Anyone know a part number for these
jacwjames Posted March 4, 2022 Posted March 4, 2022 Here's a source but you should check around https://www.braddandhall.com/ProductCart/pc/viewCategories.asp?idCategory=111
Guest Dive Dive Posted March 4, 2022 Posted March 4, 2022 The part number on my Automotion shade was faded but when I pulled the motor out it’s part number was visible. On the Bradd and Hall site there’s a little chart the cross references old part to the replacement. When I looked at it it seems like a lot of old numbers are all be replaced by the same new part number. The lady told me to always order with the adapter just in case you need it. It does not cost extra. You might call them to see if there are other means to identify a part such as measurements.
LakeBob Posted March 10, 2022 Posted March 10, 2022 Tom, how did you reprogram your shade? I’m trying to reprogram by driver side shade, which is only operated by a mulitplex switch with no up or down position. I’ve effectively erased or reset the upper limit and shade will only go up a couple inches and stop. Appreciate any insight!
Tom Whitlow Posted March 11, 2022 Posted March 11, 2022 Ask the girl at MCD. She told me how to do it. I have instructions but I can't get to them right now. I think my wife pushed/managed the Cockpit Blackout Switch (above the driver) while I worked the little button on the short pigtail from the shade. It's been a while, can't remember. It's a little complicated the first time you try to do it.
TommyL Posted April 13, 2022 Posted April 13, 2022 08 Camelot. Both of our front shades would only go up and down about a inch per button push. I took both little motors apart, I know you’re not supposed to be able to,but if there junk what can you hurt! Cleaned all the gunk out tested on work bench reinstalled been working for 2 years.
LakeBob Posted April 13, 2022 Posted April 13, 2022 I did finally talk to tech support at MCD. They advised to disconnect the shade from house power and use a battery to program the limits, reversing the battery polarity to set each direction. Working on fixing the sun shade spring connection first, then will try programming on the black out. 27 minutes ago, TommyL said: 08 Camelot. Both of our front shades would only go up and down about a inch per button push. I took both little motors apart, I know you’re not supposed to be able to,but if there junk what can you hurt! Cleaned all the gunk out tested on work bench reinstalled been working for 2 years. Thanks Tommy, the motor is working fine, just need to get the limits set.
