Patrick Posted March 4 Share Posted March 4 All of a sudden the Essex 1701 keypad on my 2002 Dynasty Baroness no longer locks the entry door or bay doors. It does still unlock them all. I have reset the keypad and tried all of the lock codes. Looked at all the wires for loose connections but could see nothing wrong. The keypad must activate an actuator. Does anyone know where this is located? Link to comment Share on other sites More sharing options...
vito.a Posted March 4 Share Posted March 4 Check the brass contacts inside the door hinge. You can clean them with contact cleaner. Link to comment Share on other sites More sharing options...
Ranger Rick Posted March 4 Share Posted March 4 19 minutes ago, vito.a said: Check the brass contacts inside the door hinge. You can clean them with contact cleaner. Suggestion: During your reset of the Essex 1701 keypad did you power down the system. A power down "reboot" might be the answer. Link to comment Share on other sites More sharing options...
Johnny Mo Posted March 5 Share Posted March 5 3 hours ago, vito.a said: Check the brass contacts inside the door hinge. You can clean them with contact cleaner. Vito, do you know of a source for the brass contacts that you mentioned. One of mine is missing Link to comment Share on other sites More sharing options...
vito.a Posted March 5 Share Posted March 5 Sorry I don't. But they would be easy to make on a lathe. Take one to a machine shop and have one made. Link to comment Share on other sites More sharing options...
Johnny Mo Posted March 5 Share Posted March 5 Thanks Vito for the suggestion Link to comment Share on other sites More sharing options...
Ivan K Posted March 5 Share Posted March 5 Do you know who made your door? Similar to this? They also have a 2 contact version. Just a thought, my door is only using 2 of the 4 contacts and the whole thing can be flipped in the frame to use the other 2 if worn, as needed. Also, I doubt a bad door contact would cause a problem with you baggage doors. My TouchPad brain box is behind the gauges and uses 2 automotive type 87a relays, one to open, other to close. I had to replace one already. Not saying yours is the same but could be... Link to comment Share on other sites More sharing options...
Flyinhy Posted March 5 Share Posted March 5 (edited) I just replaced my contacts on my 01 executive. The cargo doors would lock but not the entry door. Veurinks RV has most of these parts. The actuator for my system is in the front run bay. Edited March 5 by Flyinhy Added content Link to comment Share on other sites More sharing options...
Twomed Posted March 6 Share Posted March 6 (edited) Google >>Dodge minivan sliding door contact switch. Save $$ for beer or diesel 🙂 $6 to $10 Just an old Dodge minivan sliding door switch. 🙂 Edited March 6 by Twomed link Link to comment Share on other sites More sharing options...
MHRookie Posted March 6 Share Posted March 6 My module in 2003 dynasty was behind the middle dash piece where my radio is mounted. There is a thread on IRV2 about the swap with a viper unit that explains the wiring. Link to comment Share on other sites More sharing options...
Bob Blackmon Posted March 6 Share Posted March 6 It's not the contacts on the door, it still unlocks everything. Mine will lock and unlock the basement with the door open. Check the wiring around your alarm. Link to comment Share on other sites More sharing options...
wamcneil Posted March 6 Share Posted March 6 Look for the wiring diagram/colors on the Essex and test by grounding the Lock outputs at the back of the Essex. The Essex works by grounding a wire, which provides ground ‘signal’ to a lock relay. By grounding each of the lock/unlock wires you can determine if the problem is internal to the Essex, or something in the coach wiring. Cheers Walter Link to comment Share on other sites More sharing options...
Patrick Posted March 6 Author Share Posted March 6 7 hours ago, wamcneil said: Look for the wiring diagram/colors on the Essex and test by grounding the Lock outputs at the back of the Essex. The Essex works by grounding a wire, which provides ground ‘signal’ to a lock relay. By grounding each of the lock/unlock wires you can determine if the problem is internal to the Essex, or something in the coach wiring. Cheers Walter Walter, Thanks for the advice. I jumped the black wire (ground) to the white wire (unlock) and the doors all unlocked. Jumping the ground wire to the orange wire (lock) all the doors unlocked. This seems to indicate that the keypad is bad. I haven’t removed the keypad yet to diagnose as I didn’t know if there were any user serviceable parts inside. At worst, I could install a push button switch that jumped the ground and lock wires as a cheap solution. It’s mainly the bay doors that I want to lock and unlock remotely, without having to go around and manually lock each with a key. Do you think there any point removing the keypad? Link to comment Share on other sites More sharing options...
wamcneil Posted March 6 Share Posted March 6 I don't think you'll find anything serviceable if you remove the keypad. Link to comment Share on other sites More sharing options...
MHRookie Posted March 7 Share Posted March 7 The wiring all goes to the brain box in the dash. The keypad is just another key fob just mounted on the coach. If you depress the lock function on your keychain & nothing happens, it’s not related to the number pad… it’s the control box in dash Link to comment Share on other sites More sharing options...
Patrick Posted March 7 Author Share Posted March 7 40 minutes ago, wamcneil said: I don't think you'll find anything serviceable if you remove the keypad. Thanks Walter. I didn’t think so. Momentary switch it is for now. Link to comment Share on other sites More sharing options...
