RS lakeshore Posted March 5 Share Posted March 5 The ice maker quit making ice on our rescent trip to the Monacoers rally. It had not been used since our last trip 3 months ago. I pushed the reset/test button an the motor ran but still no ice. Has anyone else had the same problem? The water valve for the ice maker is on. Thanks for your help. Richard Silcox Link to comment Share on other sites More sharing options...
Scotty Hutto Posted March 5 Share Posted March 5 Richard, I had the same issue about a year ago. It was as simple as defrosting the water tube feeding the ice maker with a blow dryer. Had to pull the ice maker to figure it out, but once it was thawed it has worked well since. It had frozen while I had the ice maker off for a few weeks in storage Hope yours is that easy to fix!! Scotty Link to comment Share on other sites More sharing options...
jacwjames Posted March 5 Share Posted March 5 Only other thing is to make sure the button at the top control panel is on. They don't provide very good instructions on this and I forget whether the light has to be on or off. Next time I'm going to make a label so I don't have to look it up in the manual or on line. Link to comment Share on other sites More sharing options...
Jim Byrd Posted March 5 Share Posted March 5 The ice maker is OFF when the light ON Link to comment Share on other sites More sharing options...
Dr4Film Posted March 6 Share Posted March 6 Richard, I agree with Scotty, look to see if water is entering the tray after you push the reset button at the bottom. If no water is filling up the tray then you won't get any ice. Link to comment Share on other sites More sharing options...
RS lakeshore Posted March 6 Author Share Posted March 6 The refrigerator is off while in storage. I am wondering if it might be the water fill valve after reading many articles. Not able to see a access to it from the driverside outside access panel. In the videos I have watched they had a removable panel but mine doesn't. Was hoping for a easy fix. Thanks. Richard. Silcox Link to comment Share on other sites More sharing options...
Ivylog Posted March 6 Share Posted March 6 Previous ice maker in a NoCold needed water added to the tray to get it to start making ice. Link to comment Share on other sites More sharing options...
