willbo777 Posted April 5, 2022 Share Posted April 5, 2022 I wonder if Hendersons in OR would do the same alignment as Josam's? Link to comment Share on other sites More sharing options...
Chargerman Posted April 5, 2022 Share Posted April 5, 2022 That’s still a heck of a haul from Phoenix. I’ve am having a bit of a hard time understanding how a very slight misalignment of the drive axle would cause the Coach to pull one way or the other. In my mind this would only cause it to crab walk very slightly, an unnoticeable amount unless it was significantly misaligned. It seems like the biggest issue with a slightly misaligned drive axle would be premature wear of the tag axle tires. What am I missing? Link to comment Share on other sites More sharing options...
Hypoxia Posted April 5, 2022 Share Posted April 5, 2022 Massey's Truck & Tank Repair, Inc 1429 S 59th Ave, Phoenix, AZ 85043 Highly recommended by friends with RV's Link to comment Share on other sites More sharing options...
Ivylog Posted April 5, 2022 Share Posted April 5, 2022 Before I would realign a drive axle, assuming it’s what causing it to pull left, and while not a fan of a steering stabilizes; I would add one and adjust so it doesn’t pull left after swapping the front tires, that worked for me when mine started pulled one way. 9 hours ago, Chargerman said: I’m having a bit of a hard time understanding how a very slight misalignment of the drive axle would cause the Coach to pull one way or the other. In my mind this would only cause it to crab walk very slightly, an unnoticeable amount unless it was significantly misaligned. It seems like the biggest issue with a slightly misaligned drive axle would be premature wear of the tag axle tires. What am I missing? I’m with you although the drive going one way and the tag the opposite could put a pull on the front. While not a fan of steering stabilizers, I would add one and adjust the pull out before spending money on realigning axles. I don’t know anyone who wears their tires out. Link to comment Share on other sites More sharing options...
Guest azlein Posted April 5, 2022 Share Posted April 5, 2022 Thanks so much for everyone feedback, do love this site! Ivylog, which brand did you use? Link to comment Share on other sites More sharing options...
Ivylog Posted April 6, 2022 Share Posted April 6, 2022 Previous Owner put a Safe-T-Plus on our 08 Navigator which I removed until I could make it adjustable (change center position) on the fly. Posted about this here: https://www.irv2.com/forums/f258/making-a-safe-t-plus-adjustable-451209.html Link to comment Share on other sites More sharing options...
amphi_sc Posted April 6, 2022 Share Posted April 6, 2022 Henderson's in Oregon was mentioned and they do supply good alignment parts to Josam's in Florida and other shops. I do have their drag link. Another remote possibility could be the front axle got tweaked throwing off the caster. All Wheel in Redding CA also works with Henderson's parts but can also apply twists to the axle that Henderson's can't/won't do. They (as will Henderson) check rear to front tracking and most important they will do heavy work on RVs. Some heavy truck places won't touch an RV but do great work on a Pete. At least All Wheel is closer to Phoenix than Oregon or Florida. https://allwheelinc.com/ They do a lot of axle work and axle replacement. I have visited all three shops mentioned for various reasons. Hope to never need them again, but would go to any of the three if needed. Had a local truck shop work on the rig once, and they removed some shims to set it better "for freeway handling". After the fact, IMHO, that wasn't the right thing to do especially when I drove on some more heavily crowned two lane roads. My rig manuals explicitly said certain parameter settings that the local shop "knew better" from their heavy truck experience. Oh well, it's all better now and I won't go to that local heavy truck shop ever again. I think the height, center of gravity, air bag suspension, etc make the RV a different beast than a Pete. JMHO Link to comment Share on other sites More sharing options...
W7BE_Bob Posted April 7, 2022 Share Posted April 7, 2022 Henderson's Lineup in Grants Pass, OR, combine it with a trip. Link to comment Share on other sites More sharing options...
Bill R Posted December 7, 2023 Share Posted December 7, 2023 @zmotorsports Mike, you are "That Guy" in this post. Now that you are part of Monacoers we can be more formal. I'm curious, did your fix work? I have a constant pull to the left on my coach. Going to try swapping the steer tires first, all else is good that I can tell, Ride Height good, no bad brakes or suspension. Thanks. 1 Link to comment Share on other sites More sharing options...
