birdshill123 Posted April 13, 2020 Share Posted April 13, 2020 I need both gas struts for my 08 Dynasty. I have seen part numbers for other models but they list 150 lb. Struts. Infortunately mine have nothing printed on the strut. I did nottake measurements but the piston diameter is about the same as my cabinet struts. I can match the collapsed and extended lengths but need the "lb" rating. The mechanism is very complex with lots of mechanical advantage. Any help appreciated. Link to comment Share on other sites More sharing options...
bellr1968@gmail.com Posted April 14, 2020 Share Posted April 14, 2020 2 hours ago, birdshill123 said: I need both gas struts for my 08 Dynasty. I have seen part numbers for other models but they list 150 lb. Struts. Infortunately mine have nothing printed on the strut. I did nottake measurements but the piston diameter is about the same as my cabinet struts. I can match the collapsed and extended lengths but need the "lb" rating. The mechanism is very complex with lots of mechanical advantage. Any help appreciated. On my 08 Dynasty the part number on the strut is 752991-06 if that helps. 5 minutes ago, bellr1968@gmail.com said: On my 08 Dynasty the part number on the strut is 752991-06 if that helps. I see on the specs for that part number that it is 23.03 inches and has a 140# lift. My Dynasty is 45' Yorkshire plan. Russ Link to comment Share on other sites More sharing options...
birdshill123 Posted April 14, 2020 Author Share Posted April 14, 2020 Thanks for the help. This forum is quickly becoming the go to for Monaco owners. It is about 18 degrees outside and snowing so I cannot check out the dimensions. Maybe tomorrow afternoon. Thanks again. Link to comment Share on other sites More sharing options...
eddie4ne Posted April 14, 2020 Share Posted April 14, 2020 Can anyone help with the part number for engine strut for 2002 Windsor? Thanks, Ed & Sharon Link to comment Share on other sites More sharing options...
Mel S - '96 Safari Posted April 14, 2020 Share Posted April 14, 2020 14 hours ago, birdshill123 said: Thanks for the help. This forum is quickly becoming the go to for Monaco owners. It is about 18 degrees outside and snowing so I cannot check out the dimensions. Maybe tomorrow afternoon. Thanks again. "Monacoers" HAS BEEN "the go to for Monaco owners" for many years. 1 1 Link to comment Share on other sites More sharing options...
birdshill123 Posted April 14, 2020 Author Share Posted April 14, 2020 MEL. I disagree. The Yahoo format was always horrible As time went on it got worse. Lots of good information but difficult to navigate Posters tended to be brief and the info was scattered. Was not the fault of the forum owners. All Yahoo forums were similar The new forum is super Link to comment Share on other sites More sharing options...
Tom Cherry Posted April 14, 2020 Share Posted April 14, 2020 NOTE...for all folks replacing the struts. Monaco, at least on the Camelots, had some "issues". If your "high mechanical advantage" scissors and support system is like mine....then check the NUTS. Some folks....way back when....had some of the nuts come off. Some DOUBLE nutted. Others put in the Nylon Patch Lock Nuts. Make SURE that you note (this is memory from 10 years ago)....where the washers are. I THINK that the washers were there on each end of the bolt as a "Wear or spacer surface". Again....I am really fuzzy. BUT, some folks lost one of the bolts and it was a calamity.... SO....whilst in there....check the bolts and the nuts. YES....this is a great site.... Link to comment Share on other sites More sharing options...
birdshill123 Posted April 14, 2020 Author Share Posted April 14, 2020 Good MEL. I disagree. The Yahoo format was always horrible As time went on it got worse. Lots of good information but difficult to navigate Posters tended to be brief and the info was scattered. Was not the fault of the forum owners. All Yahoo forums were similar The new forum is super Tom. Good tip. I usually take pictures. Link to comment Share on other sites More sharing options...
Dave Pumphrey Posted May 8, 2020 Share Posted May 8, 2020 I need to replace mine on a 2000 Dynasty. Extended length is 26, travel is 9.5. I just don't know weight, no markings. Thanks for suggestions... Link to comment Share on other sites More sharing options...
MSHappyCampers Posted May 21, 2020 Share Posted May 21, 2020 I replaced the struts on our 2002 Windsor a while back. They are 160 Lbs each. 🙂 Link to comment Share on other sites More sharing options...
