nyrngrz Posted April 8, 2022 Share Posted April 8, 2022 The last 2 days I was dry camping using the water pump. Yesterday I shut off the water pump and traveled to an RV Park. I am currently hooked up to city water. The water pump switch is off but every minute or so I hear the water pump sound like it is providing water to the coach. Why would I hear the water pump? Link to comment Share on other sites More sharing options...
Gary M Posted April 8, 2022 Share Posted April 8, 2022 Maybe switch is stuck on. Check for power on both sides of switch in off position. Link to comment Share on other sites More sharing options...
cbr046 Posted April 8, 2022 Share Posted April 8, 2022 Or the light went out in the indicator. There's also another pump switch in the wet bay (that light doesn't work on mine). The switch actually triggers some sort of flip-flop circuit. I don't know how or where the circuit is located but a momentary press of the switch triggers the pump (on or off). The pump shouldn't go on at any time if the city water pressure is up to snuff (whatever snuff is). - bob Link to comment Share on other sites More sharing options...
Gary M Posted April 8, 2022 Share Posted April 8, 2022 3 minutes ago, cbr046 said: Or the light went out in the indicator. There's also another pump switch in the wet bay (that light doesn't work on mine). The switch actually triggers some sort of flip-flop circuit. I don't know how or where the circuit is located but a momentary press of the switch triggers the pump (on or off). The pump shouldn't go on at any time if the city water pressure is up to snuff (whatever snuff is). - bob Yeah I forgot about that pump thingy. Saw mine way up behind wetbay panel. Link to comment Share on other sites More sharing options...
OhReally Posted April 8, 2022 Share Posted April 8, 2022 Nyrngrz, you may still get the pump cycling if you have very poor city pressure or flow rate. When turned on, the pump is actuated by a pressure drop in the line so if it is cycling when you think it is turned off, you probably have a stuck pump controller or your switch is actually on. Link to comment Share on other sites More sharing options...
Andy Clark Posted April 10, 2022 Share Posted April 10, 2022 OR....the valve that you open to fill your water tank from the hose is either leaking or has been left slightly open. This leak feeds water to the water tank a little at a time and so drains pressure slowly from the system so the pump periodically tries to bring the pressure back up. Been there, done that..... Andy '95 Beaver Patriot Geo Tracker (4Dr/4WD) Toad Link to comment Share on other sites More sharing options...
