Hancoman Posted April 9, 2022 Share Posted April 9, 2022 On a recent trip in the motor home, on a cold morning turned the furnace mode on in the bedroom the fan made a loud noise and then eventually stopped . That fan is under the bedroom vanity the fan on the other side of the room still runs fine. The question is is the fan accessible by lifting the shelf under the sink. 2001 executive. Thanks in advance. Tom Link to comment Share on other sites More sharing options...
Garry Donohue Posted April 9, 2022 Share Posted April 9, 2022 Before checking fan, go outside to Aqua hot and look at the indicator lights to make sure that circuit is operating fine. Link to comment Share on other sites More sharing options...
willbo777 Posted April 9, 2022 Share Posted April 9, 2022 Yes, it should be quite accessible after lifting the cabinet bottom. Link to comment Share on other sites More sharing options...
DavidL Posted April 9, 2022 Share Posted April 9, 2022 The fans (2) typically just mount to the front of the radiator that might be in the kick board of the cabinet. So, the work is figuring out how to access it. Start by taking the grill out and then you should be able to see how the radiator is screwed to the floor/ cabinet. I would upgrade to a Noctua fan that are super quiet. Here is a quick google example https://www.amazon.com/Noctua-NF-S12A-PWM-chromax-Black-swap-Premium-Grade/dp/B07657VBQQ/ref=sr_1_1_sspa?keywords=noctua+computer+fan+120mm+nf-s12a&qid=1649537908&sprefix=computer+fan+noc%2Caps%2C109&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyMjVRUVgzSFMxSjdFJmVuY3J5cHRlZElkPUEwMDYzNDA5M0xETVdLRVhFMUVWTCZlbmNyeXB0ZWRBZElkPUEwMDM0MDkzMUMwUkdCWVdQT1k4MyZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= Link to comment Share on other sites More sharing options...
Hancoman Posted May 11, 2022 Author Share Posted May 11, 2022 Finally got back to the coach to check on the furnace fans. Pulled up the cabinet bottom to expose the fans. The question I have is is it normal for both fans to go out simultaneously, or should I be looking for fuse or something else. Thanks Tom Link to comment Share on other sites More sharing options...
