sg47619 Posted April 12, 2022 Share Posted April 12, 2022 My 01 Monaco has two water filters. I thought I wrote the numbers down now I can’t find them. Does anyone know what I need to buy. Link to comment Share on other sites More sharing options...
Bill C Posted April 12, 2022 Share Posted April 12, 2022 My 01 Dynasty uses these filters https://smile.amazon.com/gp/product/B01MF60BVT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
timaz996 Posted April 12, 2022 Share Posted April 12, 2022 Just what Bill said/listed. I adder a whole house UV filter also because I full time. It's the stainless steal one in the picture. Tim Link to comment Share on other sites More sharing options...
Bill C Posted April 12, 2022 Share Posted April 12, 2022 What,s the UV filter do? Link to comment Share on other sites More sharing options...
Land Lubber Posted April 12, 2022 Share Posted April 12, 2022 I use a 0.5 micron sediment filter followed by a 0.5 micron carbon block filter in my Camelot. A good primer to learn about water filters is at the RV Water Filter Store, https://www.rvwaterfilterstore.com/filter-cartridges. You can buy filters most anywhere but Dave's site has some good info on the different types available to suit your needs. Link to comment Share on other sites More sharing options...
StephenW Posted April 12, 2022 Share Posted April 12, 2022 The UV filters are used to kill bacteria and are often used on well systems. Link to comment Share on other sites More sharing options...
timaz996 Posted April 12, 2022 Share Posted April 12, 2022 1 hour ago, Corkman said: What,s the UV filter do? As Stephen said, it kills bacteria. This way I'm not breathing in nasty stuff in the shower and I can cook and drink the water from my tank. The water goes through my filters both when I fill the tank and is pumped through them when I use it in the coach. I get my filters and including the UV filter from the water fixer. No affiliation. https://www.waterfixercompany.com/modelwf1000.html Link to comment Share on other sites More sharing options...
timaz996 Posted April 12, 2022 Share Posted April 12, 2022 I should have said that you can just buy the UV filter and add it to your filters you already have. Just make it the last one in line. Tim Link to comment Share on other sites More sharing options...
jacwjames Posted April 13, 2022 Share Posted April 13, 2022 I have a UV filter in my house because we are on well water. It is a large unit, 25gpm. One thing to note is that the bulb (at least on my unit) has to be changed annually as the UV output degrades with age. The controller actually has a 365 day countdown timer. Not a big deal if you install the system with that in mind. My bulb is about 30" long and is in a quartz sleeve. I had an unused threaded port and installed a glass lenses so I could make sure the light is working, the light is on all the time. I initially had it wired to come on with the well pump but the controller failed pretty quickly, cost was ~$180, and after reading more it recommended leaving it on all the time. I keep spare bulbs and sleeves, and check the system 3-4 times per week just to make sure all is good. I also installed a sediment filter prior to the UV light, this helps keep the water going to the UV light clean. So my concern in using one in the RV would be how robust the UV bulb is as mine has a long signal strand filament, Same with the quartz sleeve, last time I pulled my quartz sleeve to clean and when I reinstalled I did not center the quartz lenses and ended up cracking it. Luckily I had a spare. Link to comment Share on other sites More sharing options...
timaz996 Posted April 13, 2022 Share Posted April 13, 2022 You can read the specs on the link I posted. There is a glass piece to look though and see that it is working. It seems to last a little over two years. You can contact them for pricing on just the UV filter assembly like I did. Tim Link to comment Share on other sites More sharing options...
Paul J A Posted April 14, 2022 Share Posted April 14, 2022 https://www.watts.com/ Can provide answers to any ???????? you have, and product to aquire the product for the results you want/persue. Link to comment Share on other sites More sharing options...
