TDaleABQ Posted April 16 Share Posted April 16 Hello, I have a 2007 Monaco Knight. I am attempting to pull the cover (see image) so I can get to low drains and water pump. Has anyone taken this off and if so how did you get it out. I have everything disconnected on the back side. Thanks Tim ABQ Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted April 16 Share Posted April 16 (edited) I removed the whole panel and just used pieces of the panel for mounting purposes. It got to be a pain getting to problems behind the panel. I also found an extra storage area in the upper right corner. I also moved the water pump up front instead of the lower left back corner. Gary 05 AMB DST Edited April 16 by Gary 05 AMB DST more info Link to comment Share on other sites More sharing options...
TDaleABQ Posted April 17 Author Share Posted April 17 Gary, Thanks a lot. That looks great and hope you don't mind if I copy that. I am also going to take the macerator pump out that is in the left lower area and get more storage there too. I never use the thing. My Dometic toilet has one built in. TimDABQ 2007 Monaco Knight SKT (bought it new) Gary, Have you ever messed with the tank sensors? Mine have never registered correctly. I have tried the cleaners to add to tanks and replaced the board on the control panel inside. Thanks Link to comment Share on other sites More sharing options...
Fasthobie16 Posted April 17 Share Posted April 17 Have you ever re-calibrated the tank sensors? It’s done with the touch pad buttons on the tank indication panel. If I remember right, you hold the button till it flashes ( I think) on the tank that is full. Then empty out completely an hold the button again. Hope that helps. My tank levels were off an that fixed them. You can do the reverse process on your fresh water tank (or others if you like). Just don’t over fill the black or grey tanks.😭😡🤬 Jim 2000 Dynasty Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted April 17 Share Posted April 17 Tim,. I did have to make that aluminum bar that everything had to attach to. 1/2"x1/2" aluminum angle and flat aluminum panel. I've had bad luck with the sensors, so I just live with it. I'll try what Fasthobie16 suggested. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
LarryB Posted April 17 Share Posted April 17 Howdy Tim. I too was frustrated over the access/removal of this plate. Eventually I cut straight up from the center of the picture of the toilet near the bottom left of center. I removed any plumbing n used a short saw blade. Link to comment Share on other sites More sharing options...
TDaleABQ Posted April 17 Author Share Posted April 17 Larry, That looks really clean. What did you us on the back to piece the two sides back together? Thanks Tim Link to comment Share on other sites More sharing options...
LarryB Posted April 17 Share Posted April 17 A pc of aluminum roughly 1/8” x 2” x what ever the length u need. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted April 18 Share Posted April 18 But you still have to disconnect everything to remove the panel. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Frank McElroy Posted April 22 Share Posted April 22 On 4/17/2022 at 11:53 AM, LarryB said: Howdy Tim. I too was frustrated over the access/removal of this plate. Eventually I cut straight up from the center of the picture of the toilet near the bottom left of center. I removed any plumbing n used a short saw blade. Larry, do you always leave the fresh water to tank flush hose connection in place? My practice is to connect a separate hose to the tank flush connection only when I need to tank flush in order to prevent any possibility of contaminating my fresh water supply. 2 Link to comment Share on other sites More sharing options...
