StillRunning_60 Posted April 17 Share Posted April 17 A problem a lot of Windsor owners have is the deck plate for the sewer hose is off center. After 4 years of this I finally replaced my original 6 inch deck plate with a larger one which was not that hard of a job. Now much easier to run sewerage hose. 1 1 Link to comment Share on other sites More sharing options...
Corkman Posted April 17 Share Posted April 17 (edited) Mine is hard to line up as well, but about 7 years ago I switched to the Valterra SS01 RV SewerSolution Drainage system and have loved it ever sense. Here is a Link to Valterra SS01 RV SewerSolution Drainage Kit with 10' Hose and Accessories I highly recommend it, and it is a lot less messy. Bill Edited April 17 by Corkman Link to comment Share on other sites More sharing options...
sg47619 Posted April 17 Share Posted April 17 1 hour ago, StillRunning_60 said: A problem a lot of Windsor owners have is the deck plate for the sewer hose is off center. After 4 years of this I finally replaced my original 6 inch deck plate with a larger one which was not that hard of a job. Now much easier to run sewerage hose. Where did you purchase the bigger opening Link to comment Share on other sites More sharing options...
myrontruex Posted April 17 Share Posted April 17 2008 Endeavor with same issue. Resolved long ago. It seems this is a common problem. What I wanted to add is the modification idea stolen long ago on the faces of the valves. Notice a small stainless screw on the face of each of them. Removing them allows injection of silicon spray to keep the valves smoother than new. Simple mod and really has been great. In use for probably six years. Myron T Link to comment Share on other sites More sharing options...
StillRunning_60 Posted April 17 Author Share Posted April 17 There is a lot of them on Amazon just google deck plates. I purchased the 10 inch but probably the 8 inch would have worked. Link to comment Share on other sites More sharing options...
sg47619 Posted April 17 Share Posted April 17 Ok thanks Link to comment Share on other sites More sharing options...
sg47619 Posted April 20 Share Posted April 20 2 hours ago, Dales 2K Exec. said: Boat supply stores. On the shelf. Thanks Link to comment Share on other sites More sharing options...
6Wheels Posted April 21 Share Posted April 21 With all the nice pictures I have a question. How do you keep critters from scooting up the opening into the basement? Link to comment Share on other sites More sharing options...
Paul A. Posted April 21 Share Posted April 21 Do the same with one for the water hose and power cord. 2 Link to comment Share on other sites More sharing options...
Hypoxia Posted April 22 Share Posted April 22 (edited) 11 hours ago, 6Wheels said: With all the nice pictures I have a question. How do you keep critters from scooting up the opening into the basement? I made 1/2" thick polyethylene plastic plates with a slot for the wire/hose which is heavy enough to discourage most. Paul's is much better and would keep out the occasional meercat, gopher, roof rat as well as the other critters. Edited April 22 by Hypoxia Link to comment Share on other sites More sharing options...
dl_racing427 Posted April 22 Share Posted April 22 That is a great idea Paul, cheap, easy and should be very effective. 😎 Link to comment Share on other sites More sharing options...
6Wheels Posted April 22 Share Posted April 22 I like it! Link to comment Share on other sites More sharing options...
