sg47619 Posted April 17 Share Posted April 17 Has anyone had one of these fittings do this. Had antifreeze running across the floor in my 01 Monaco Dynasty. Link to comment Share on other sites More sharing options...
DavidL Posted April 17 Share Posted April 17 Freeze damage? Easy fix. pull out the hose, clean the fitting, put a new collar / nut over the tube, put the crush coupling on the end of tube, push the tube until it won't go into the fitting anymore and snug the nut. Link to comment Share on other sites More sharing options...
sg47619 Posted April 17 Author Share Posted April 17 I thought these wouldn’t freeze since there is antifreeze running through the aqua hot lines. Link to comment Share on other sites More sharing options...
DavidL Posted April 17 Share Posted April 17 re: antifreeze - good point! Link to comment Share on other sites More sharing options...
sg47619 Posted April 17 Author Share Posted April 17 I wander if I should check how good it is. It’s in a 01 Monaco and I’m sure it’s never been changed Link to comment Share on other sites More sharing options...
