sg47619 Posted April 19 Share Posted April 19 My 01 Monaco Dynasty has this BOSE system in it I can’t get it to power up and work. Anyone have any ideas it also has a unit under the sink I had to remove to fix a heater line fitting that’s was leaking. Not going to reinstall if it’s not worth messing with. Thanks in advance. Link to comment Share on other sites More sharing options...
Frank Bergamo Posted April 19 Share Posted April 19 The big object is probably a Bose Acoustimass. If it got wet, then you will need to repair or replace it. I have one that got wet and will not work as you describe. Found one on E-bay, have not had time to replace it yet. Also, there is a fuse inside, that may be your problem. Hope this helps. Link to comment Share on other sites More sharing options...
Dr4Film Posted April 19 Share Posted April 19 Chuck B is our resident BOSE expert. Hopefully he will see this thread or send him a PM. Link to comment Share on other sites More sharing options...
SigPIlot Posted April 19 Share Posted April 19 Had the same problem. Kept the speakers and installed a Yamaha AVR (Costco) and Sub Woofer. AVR went in an overhead cabinet next to the door. Power already there for Dish receiver and satellite. Added a good surge protector. Power already under sink for Acoustimass. Ran wiring from avr to sub woofer behind j couch etc. Ran dish to avr. Added DVD player. That with new flat screen (Samsung) in place of old Sony makes it all sweet. Was a pretty easy install. Hardest part was getting the old Bose anchor out from behind the sink. Sounds great! Link to comment Share on other sites More sharing options...
Tim-AZ Posted April 19 Share Posted April 19 I had the same problem with mine and I read through the troubleshooting in the manual. Unplug the control head from power for a few minutes and then plug it back in. If it saw any kind of power spike it shuts down. Doing this will reset it. Tim Link to comment Share on other sites More sharing options...
joefromperry Posted April 19 Share Posted April 19 I have a 2003 signature and want to change out all the old audio, the Bose, the vcr, the satellite stuff, etc. I'd like to do what SigPilot above did. Can I get specifics on what I need to do? I'm not sure where my subwoofer is, but can it be used with a new system? Thanks. Link to comment Share on other sites More sharing options...
sg47619 Posted April 20 Author Share Posted April 20 On 4/19/2022 at 11:56 AM, Tim-AZ said: I had the same problem with mine and I read through the troubleshooting in the manual. Unplug the control head from power for a few minutes and then plug it back in. If it saw any kind of power spike it shuts down. Doing this will reset it. Tim I tried that. Still won’t power up Link to comment Share on other sites More sharing options...
