Romeo84 Posted April 19, 2022 Share Posted April 19, 2022 Anyone ever fill the air tanks through the auxiliary fill connect. I know it doesn't go through air dryer but I want to air it up to look for leaks and would be way easier without running the coach at idle for an hour. Link to comment Share on other sites More sharing options...
96 EVO Posted April 19, 2022 Share Posted April 19, 2022 Yeah, I've done it. After filling the tanks to 120-125psi, I leave it sit about an hour, then crack each drain for a second. Link to comment Share on other sites More sharing options...
Romeo84 Posted April 19, 2022 Author Share Posted April 19, 2022 Thanks for the fast reply. Do you have the fill In front next to the generator or by the Lp tank? Link to comment Share on other sites More sharing options...
96 EVO Posted April 19, 2022 Share Posted April 19, 2022 Yeah, my fill port and tank drains are on a manifold in the generator compartment. Link to comment Share on other sites More sharing options...
Romeo84 Posted April 19, 2022 Author Share Posted April 19, 2022 Thanks! Link to comment Share on other sites More sharing options...
Ivan K Posted April 19, 2022 Share Posted April 19, 2022 (edited) Since we have the same coach, our fill is the male nipple on driver side of generator. I use it all the time in the shop when I need to raise it or work on any air accessory. And contrary to my previous belief, it goes to wet tank so at least that. Edited April 19, 2022 by Ivan K 1 Link to comment Share on other sites More sharing options...
Romeo84 Posted April 19, 2022 Author Share Posted April 19, 2022 2 hours ago, Ivan K said: Since we have the same coach, our fill is the male nipple on driver side of generator. I use it all the time in the shop when I need to raise it or work on any air accessory. And contrary to my previous belief, it goes to wet tank so at least that. Hey if you happen to be by your rig can you send a pic?I have looked high and low in the front end and nothing. I do have a port in the LP tank are but nothing up front Link to comment Share on other sites More sharing options...
Ivan K Posted April 20, 2022 Share Posted April 20, 2022 Here you go. Hope it helps. The only shiny thing in the pic 🙂 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted April 20, 2022 Share Posted April 20, 2022 You can buy an air dryer filter that attaches to the air line or the nipple. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Romeo84 Posted April 20, 2022 Author Share Posted April 20, 2022 14 hours ago, Ivan K said: Here you go. Hope it helps. The only shiny thing in the pic 🙂 Also thanks Ivan. Not the first time you helped me. It's in that exact spot. Couldn't see it as it was completely rusted over...weird they used steel instead of brass fitting Link to comment Share on other sites More sharing options...
