Al redcay Posted April 24 Share Posted April 24 When do you need to turn on inverter in coach . Link to comment Share on other sites More sharing options...
DavidL Posted April 24 Share Posted April 24 (edited) When you need to use 110 volt devices and 110 volts is not available from a landline or you don't want to turn on your generator (if equipped). An Inverter converts 12 volts DC to 110 Volts AC. If your trailer has one, then you should have several outlets (not necessarily all) that can be powered off of battery when Inverter is turned on. High amperage devices (microwave, electric oven, hair dryers) might consume more electricity than your Inverter is rated for. Edited April 24 by DavidL Link to comment Share on other sites More sharing options...
jacwjames Posted April 24 Share Posted April 24 Initially we only used the inverter to watch TV. If we needed the microwave we'd start the generator. In 2019 I installed a residential refrigerator, so now while traveling have to have the inverter on all the time. Link to comment Share on other sites More sharing options...
Al redcay Posted April 24 Author Share Posted April 24 Does it hurt if you leave it on all the time . Link to comment Share on other sites More sharing options...
Doug J Posted April 24 Share Posted April 24 Mine has been on continuously for the last 15 years. 2003 Navigator. No problems. Link to comment Share on other sites More sharing options...
Old Dog Posted April 24 Share Posted April 24 Today's inverters have a pass through function that sends 110v out whenever it's available and only inverts when not available. Not sure how far back that feature goes for which brands/models. Link to comment Share on other sites More sharing options...
vito.a Posted April 24 Share Posted April 24 I leave ours on 24/7. It has two functions. One is to charge your house batteries and the second is to invert 12v from the house batteries into 120v AC to a few systems in the coach. Have you reviewed your owners manual to see what it says? Link to comment Share on other sites More sharing options...
tomevansfl Posted April 24 Share Posted April 24 While in storage between trips I turn the battery cut-off to the off position. We have a residential fridge so the day before a trip I go to the storage lot to turn the battery cut-off to the on position and turn the inverter on. In 24 hours our fridge cools down to operating temp and uses less than 50% of the batteries. I leave it turned on until we put our RV in storage again. Link to comment Share on other sites More sharing options...
