bret trickett Posted April 24 Share Posted April 24 Ok looking help and guidance. I got a 2005 diplomat last fall I notice wet floor next to the drivers seat So I bought a cover to get through winter until I could address the roof. Yesterday removed cover and resealed seams on the roof. Went inside an the floor is wet? Trying to come up with reasons why it would be wet with a cover over the rv? Roof was not that bad any ideas where to look next? thanks Link to comment Share on other sites More sharing options...
klcdenver Posted April 24 Share Posted April 24 I would suspect the drivers side window is leaking and it is running down the wall to the floor under the side console. Link to comment Share on other sites More sharing options...
JDCrow Posted April 24 Share Posted April 24 Mine was the slide topper sagging and letting water puddle and would become to much water for the slide seal to keep out. Monaco has an issue in the area (lower corner of slides and there was a fix from factory. Link to comment Share on other sites More sharing options...
top flight Posted April 24 Share Posted April 24 Had the same problem, mine was also the side window. I loosened all the screws around the inside frame, re sealed with high quality sealant, tightened screws, no more leaks. Since then I've gone round all of the windows and made sure that the screws were tight. Link to comment Share on other sites More sharing options...
