2006 monaco holiday rambler driver side. Side sun shade.
Same happened with both of mine.
Disassembled it, sprayed some lubricating oil inside the tube and reassembled with increased spring tension.  Been fine since. Very easy to do.
I did mine with it pulled down (and unattached from the coach).  Took it apart, oiled up the tube and spring then reassembled it. Just put a bit of tension on it - comparable to what I felt like it was - and cycled it up and down.  I increased the tensions slightly each time, cycling it each time until I was happy with how it retracted.  Then reinstalled to the coach.
It really is quite simple, you’ll get what I'm saying when you take it apart.
Good luck!!
I've got it apart.Is your spring full length mine is only a foot long with a sponge circle on one end hold it centered so when I try to put tension on the spring the whole spring turns.
Thank you for your patience.
 Share
