Bobbyboy Posted April 22, 2020 Share Posted April 22, 2020 I have a 10KW onan in my 08 dynasty. I am not getting 12V to fuel pump; I disconnected the fuel pump and applied external 12 V to it and the pump works; however it you push the rocker switch down the pump is supposed to work and it doesn't. Now, after i run the pump with the external power source, the genny starts right up but only runs for a few minutes until all the fuel is pulled from the filter then it shuts down. If I try the rocker switch to prime and start, the pump will not run. Obviously, not getting 12V to the pump. also put the voltmeter on the two leads going to the pump and push the rocker switch--no voltage. This is true for both the remote rocker switch and the one on the genny. anybody got any ideas as to where the "missing voltage" is hung up. Obviously, the switch works as the genny will turn over--but the pump will not engage Thanks, Bob L, 08 dynasty Link to comment Share on other sites More sharing options...
Dennis H Posted April 22, 2020 Share Posted April 22, 2020 Bob, passenger side of the genset at the top is a wire loom of about 10 wires. There is a connector there that is exposed to the elements. It's most likely zip tied. Open that connector and look for loose, dirty or compromised wires. Clean the connections and reassemble then try it. Best of luck....Dennis Link to comment Share on other sites More sharing options...
Bobbyboy Posted April 22, 2020 Author Share Posted April 22, 2020 Thanks Dennis; will give it a try. I know the bundle of wires you reference. If I 'hot wire" the fuel pump, the genny runs fine. Just can't get the 12 volts to the pump. from the rocker switch bob L, 08 dynasty Link to comment Share on other sites More sharing options...
Dennis H Posted April 22, 2020 Share Posted April 22, 2020 You should have three, or more, ways to turn on the genset. Did you try the bedroom switch? If you're having the same issue with all switches, then it's in that wire loom....Dennis Link to comment Share on other sites More sharing options...
OhReally Posted April 22, 2020 Share Posted April 22, 2020 I agree with Dennis. I opened the connector and bent the pins slightly to improve the connections and all is good now. Link to comment Share on other sites More sharing options...
Bobbyboy Posted April 23, 2020 Author Share Posted April 23, 2020 The bedroom switch is the same. I am thinking also that maybe there is a bad ground. Tomorrow I am going to disconnect only the ground connection from the pump and grouind the pump directly to the negative post on the battery and see if switch activates the pump; if not, then I will check all the connections and clean with electric contact cleaner. Will let you know. Bob L, 08 dynasty Link to comment Share on other sites More sharing options...
Warren B Posted April 23, 2020 Share Posted April 23, 2020 I think the low coolant and low oil switches remove 12v from the fuel pump. There is a procedure in the service manual to test, but couldn’t find a schematic to verify. Link to comment Share on other sites More sharing options...
dl_racing427 Posted April 23, 2020 Share Posted April 23, 2020 You may also have a failed fuel pump relay in the genset. It could also be fused, but that would likely be on a panel and labeled. Link to comment Share on other sites More sharing options...
Hypoxia Posted April 23, 2020 Share Posted April 23, 2020 16 hours ago, Bobbyboy said: I have a 10KW onan in my 08 dynasty. I am not getting 12V to fuel pump; I disconnected the fuel pump and applied external 12 V to it and the pump works; however it you push the rocker switch down the pump is supposed to work and it doesn't. Now, after i run the pump with the external power source, the genny starts right up but only runs for a few minutes until all the fuel is pulled from the filter then it shuts down. If I try the rocker switch to prime and start, the pump will not run. Obviously, not getting 12V to the pump. also put the voltmeter on the two leads going to the pump and push the rocker switch--no voltage. This is true for both the remote rocker switch and the one on the genny. anybody got any ideas as to where the "missing voltage" is hung up. Obviously, the switch works as the genny will turn over--but the pump will not engage Thanks, Bob L, 08 dynasty Is there an error code? What model is it? On my 2007 HDKCB Spec B 12.5Kw there is a common problem with the Generator Control Board not sending power to the fuel pump. I think it usually produces a code 36. Link to comment Share on other sites More sharing options...
Bobbyboy Posted April 23, 2020 Author Share Posted April 23, 2020 Jim: The error code is 36; I tried everything this morning-- I have a good ground; I unplugged every connection, cleaned with contact cleaner replugged but still no help. I finally broke down, took the control board out and ordered a new one from Cummins ($$$). I have the 10HDKCA, spec B. Supposed to get the new board tomorrow or Saturday. I hope that solves the problem. Bob L, 08 dynasty Link to comment Share on other sites More sharing options...
Bobbyboy Posted April 24, 2020 Author Share Posted April 24, 2020 OK---got a new board from Cummins, put it in this morning and all is well. Fuel pump works; ran genny for about an hour with a load and no problems. I have the old board and am going to see if it can be repaired so I can have a spare. By the way, the old part number for the board was 327-1501; however Cummins informed me that the new number is 300-5961. Now that is for a 10kw, Spec B with a Kubota engine. bob L, 08 dynasty Link to comment Share on other sites More sharing options...
Hypoxia Posted April 24, 2020 Share Posted April 24, 2020 Thanks for the report. That 300-5961 board is also in my 12.5 HDKCB Spec B Link to comment Share on other sites More sharing options...
