LakeBob Posted August 7, 2022 Share Posted August 7, 2022 I've pulled the dinette from our 2009 Dynasty and need to make a small panel to cover up the wiring running along the floor next to the wall. Anyone found a good over the counter stain that matches the "Natural Cherry" color woodwork in a Monaco? Thanks! Link to comment Share on other sites More sharing options...
klcdenver Posted August 7, 2022 Share Posted August 7, 2022 I had best luck with the gel stain to match my cherry wood. Do not remember the brand thou. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted August 7, 2022 Share Posted August 7, 2022 The best way to match a stain is to carry a piece of the wood you want to stain and cabinet door to a paint dealer. They should match the stain needed. A given stain will give a different tint on different woods. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
Ray Davis Posted August 7, 2022 Share Posted August 7, 2022 (edited) Chuck is right, it depends on what kind of wood you are staining. Our Windsor has cherry wood, I suppose your Dynasty does too. I found that Cherry wood will stain it's self ( darken ) Left unstained mine matched the rest of the wood in a short while. I read that somewhere and it's true. I don't believe Monaco used stain, I may be wrong about that though. Anyway, when I did need some stain I bough mine at Lowes, and as I recall it was Gun Stock. I bought 3 small cans that looked close and Gun Stock won the contest. A little goes a long way so buy small. Edited August 7, 2022 by Ray Davis Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted August 7, 2022 Share Posted August 7, 2022 The only problem you will have is a couple years later you will find that the original woods will continue to age and the stain you matched will not. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
LakeBob Posted August 7, 2022 Author Share Posted August 7, 2022 Thanks for the info and feedback. Yes, the coach wood work is cherry, and its called "Natural Cherry" on the build sheet. It's either very lightly stained or just a clear finish, just not sure. I'm planning on using poplar wood, as I haven't found a source of reasonably priced cherry wood and it's an out of the way spot that won't be noticeable if it doesn't match exactly. Link to comment Share on other sites More sharing options...
jacwjames Posted August 7, 2022 Share Posted August 7, 2022 Look at post #1014 on this IRV2 thread https://www.irv2.com/forums/f115/just-purchased-wrecked-2004-camelot-pdq-big-project-444980-73.html TRH299 "Tim" did a great job rebuilding his coach. He used a Watco SemiGloss Lacquer, no stain. I thought I had seen he had bought at Lowes but they don't carry at my store. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted August 7, 2022 Share Posted August 7, 2022 11 minutes ago, LakeBob said: Thanks for the info and feedback. Yes, the coach wood work is cherry, and its called "Natural Cherry" on the build sheet. It's either very lightly stained or just a clear finish, just not sure. I'm planning on using poplar wood, as I haven't found a source of reasonably priced cherry wood and it's an out of the way spot that won't be noticeable if it doesn't match exactly. The bitterness of a poor choice remain long after the sweetness of making that choice. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
jacwjames Posted August 7, 2022 Share Posted August 7, 2022 You might check Craigslist in your area. In E TN there are numerous adds for different types of wood, usually at a reasonable price. IMHO it would be worth the effort to find a source. I was lucky and was able to harvest ~+5000 bd ft of lumber off my proper while I was clearing and building my house (Ash, Cherry, Oak, Walnut, Sassafras, Cedar, Elm) Used a bunch on the house, still have quite a bit left. Link to comment Share on other sites More sharing options...
96 EVO Posted August 7, 2022 Share Posted August 7, 2022 43 minutes ago, Ray Davis said: Anyway, when I did need some stain I bough mine at Lowes, and as I recall it was Gun Stock. I bought 3 small cans that looked close and Gun Stock won the contest. A little goes a long way so buy small. Hmm! I installed Gunstock oak hardwood in my home, and it is a fair bit darker than the cherrywood in my coach. Link to comment Share on other sites More sharing options...
RDGreenlief Posted August 7, 2022 Share Posted August 7, 2022 I did a remodel on our 2003 Windsor with cherry wood cabinets about three years ago. Used the dinette to contruct a concealed entertainment center with cherry wood top. Used Minwax stain on the top and was very please with the match. https://www.amazon.com/Minwax-70009444-Finish-Penetrating-Cherry/dp/B000BZX5M4/ref=asc_df_B000BZX5M4/?tag=hyprod-20&linkCode=df0&hvadid=198071503086&hvpos=&hvnetw=g&hvrand=9715979298607204330&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9022304&hvtargid=pla-353531776932&psc=1 Then used a gloss poly urethane covering. RD Greenlief Link to comment Share on other sites More sharing options...
LakeBob Posted August 7, 2022 Author Share Posted August 7, 2022 18 minutes ago, jacwjames said: You might check Craigslist in your area. In E TN there are numerous adds for different types of wood, usually at a reasonable price. IMHO it would be worth the effort to find a source. I was lucky and was able to harvest ~+5000 bd ft of lumber off my proper while I was clearing and building my house (Ash, Cherry, Oak, Walnut, Sassafras, Cedar, Elm) Used a bunch on the house, still have quite a bit left. Thanks, I'll check out Craigslist. Link to comment Share on other sites More sharing options...
WayneC Posted August 7, 2022 Share Posted August 7, 2022 I had replaced the 400lb tube TV in the front,I put a piece of smooth finished plywood and stained it with Old Master penetrating stain,Cherry c40304 , then mounted the 6 lb flat screen to it,it matched up perfect with the rest of the wood.Probably picked up a few miles per gallon after throwing both tube TV out. Wayne 1999 Signature ceaser Link to comment Share on other sites More sharing options...
Ray Davis Posted August 8, 2022 Share Posted August 8, 2022 4 hours ago, 96 EVO said: Hmm! I installed Gunstock oak hardwood in my home, and it is a fair bit darker than the cherrywood in my coach. Well there you go, you never know. I imagine my gunstock stain might be dark on some wood, I don't know, but I thought oak was usually light in color and slow to stain. But, that's why my DW picks colors for me. I have to pass inspection before going out. 😁 Link to comment Share on other sites More sharing options...
LakeBob Posted August 8, 2022 Author Share Posted August 8, 2022 4 hours ago, WayneC said: I had replaced the 400lb tube TV in the front,I put a piece of smooth finished plywood and stained it with Old Master penetrating stain,Cherry c40304 , then mounted the 6 lb flat screen to it,it matched up perfect with the rest of the wood.Probably picked up a few miles per gallon after throwing both tube TV out. Wayne 1999 Signature ceaser Thanks Wayne! Link to comment Share on other sites More sharing options...
myrontruex Posted August 9, 2022 Share Posted August 9, 2022 Stain Strange color choice I know but this seems to match my Cherry very closely. I have added several large panels and this has been the best so far. Taking out my love seat, built in a Dishwasher, slide out trash can, slide out pantry, and slide out storage for large mixer and accessories. The wood grain is not as good of a match as I would like but it works. I didn't have my old workshop to do cabinetry level work. My excuse and I am sticking to it. Had plans to do a better countertop but the existing one has worked for about three years now. I guess we are just used to it. Link to comment Share on other sites More sharing options...
Ray Davis Posted August 9, 2022 Share Posted August 9, 2022 1 hour ago, myrontruex said: Stain Strange color choice I know but this seems to match my Cherry very closely. I have added several large panels and this has been the best so far. Taking out my love seat, built in a Dishwasher, slide out trash can, slide out pantry, and slide out storage for large mixer and accessories. The wood grain is not as good of a match as I would like but it works. I didn't have my old workshop to do cabinetry level work. My excuse and I am sticking to it. Had plans to do a better countertop but the existing one has worked for about three years now. I guess we are just used to it. Ah ha, Gunstock again, that's what I used. Goes to show, you can't go by the name, you gotta experiment and put some eyes on it. Link to comment Share on other sites More sharing options...
