Marine Boy Posted August 8, 2022 Share Posted August 8, 2022 I purchased first of the year, a 06 Dynasty with an ISL400 Cummins. Did full maintenance right after purchase. Just finished our first long trip with her, doing 2800 miles round trip to Oshkosh, WI from Tampa, FL. I didn't seem to have a power issue, but I would never report over a 50% load and I am getting good boost pressure. I feel I need to find a good Cummins service center to put the computer on her and go for a test ride. Ideas would be helpful, but I am really looking for a recommendation for a Cummins shop close to Tampa, FL. Thanks, John Link to comment Share on other sites More sharing options...
Mike T Phillips Posted August 8, 2022 Share Posted August 8, 2022 NEVER use Cummings power south in Tampa. Erased all of the codes in my ecm and then told me it was an Allison transmission problem. $1400. At other shops to prove it. take it to Cummings power south in Orlando. And ask for victor to work on it. Or take to Cummings freightliner in Haynes city Link to comment Share on other sites More sharing options...
Marine Boy Posted August 8, 2022 Author Share Posted August 8, 2022 33 minutes ago, Mike T Phillips said: NEVER use Cummings power south in Tampa. Erased all of the codes in my ecm and then told me it was an Allison transmission problem. $1400. At other shops to prove it. take it to Cummings power south in Orlando. And ask for victor to work on it. Or take to Cummings freightliner in Haynes city Hi Mike, Thanks for your input. I completely understand it is all about the guys doing the work. Best, John Link to comment Share on other sites More sharing options...
Ukulelemark Posted August 8, 2022 Share Posted August 8, 2022 John, I’ve used Cummins in Ocala. John the service mgr is top shelf as is the service and experience. We live in Ft Myers beach and they’re definitely worth the drive. They also have free overnight parking with hookups for their customers. Mark Link to comment Share on other sites More sharing options...
Mike T Phillips Posted August 8, 2022 Share Posted August 8, 2022 I have also used the Cummings power south in Ocala they were good also Link to comment Share on other sites More sharing options...
Tom Cherry Posted August 8, 2022 Share Posted August 8, 2022 8 hours ago, Mike T Phillips said: I have also used the Cummings power south in Ocala they were good also Authorized Cummins shop in Orlando did a complete ECM Replacement for a buddy and the mobile tech was great. Frank McElroy provided a copy of the complete Monaco parameters for the ECM, which only had the Cummins emissions info. I talked to tech and then Frank later. The rig runs flawlessly and my buddy was totally satisfied. Link to comment Share on other sites More sharing options...
Tom Whitlow Posted August 9, 2022 Share Posted August 9, 2022 Don't use the Cummins in Tampa. I've had multiple big problems with that shop. Link to comment Share on other sites More sharing options...
Marine Boy Posted August 9, 2022 Author Share Posted August 9, 2022 Thanks to all for the Great Feedback on shops. Looks like I will have to drive to get the best service. Thank Again! John Link to comment Share on other sites More sharing options...
Frank McElroy Posted August 9, 2022 Share Posted August 9, 2022 16 hours ago, Tom Cherry said: Authorized Cummins shop in Orlando did a complete ECM Replacement for a buddy and the mobile tech was great. Frank McElroy provided a copy of the complete Monaco parameters for the ECM, which only had the Cummins emissions info. I talked to tech and then Frank later. The rig runs flawlessly and my buddy was totally satisfied. Tom - I remember that. My advice to folks is that the next time a shop (either Cummins or any other shop using the Cummins Insite software) connects up to their engine computer, ask for a hard copy of the engine ECM parameter list. That way, should the Engine ECM ever fail, you'll have the information to program the replacement computer with the configuration that may have been customized to specific options on their coach. Besides the engine parameter list, on most electronic engines you can get a 50+ page report on the engine. This will show things like how the coach was driven since birth - fuel economy, use of service and engine brakes, load vs idle time, did it ever overheat and how bad, how did the last ten regeneration cycles on the DPF perform (all normal or not), the engine abuse history report and much much more. This is a must have when buying a used coach. If you want to compare how you are driving the coach vs the previous owner, ask to have the engine ECM trip function reset. Then the next time you have the service center generate a report it will show how you are driving the coach. Link to comment Share on other sites More sharing options...
dholden_us Posted August 9, 2022 Share Posted August 9, 2022 Cummins dealer on HWY301 is not good either. Said I had bad injector pump, wiring harness, 3 sensors and $16,000 to fix. The real problem was a crack in the charge air cooler Link to comment Share on other sites More sharing options...
