Rob M cKeown Posted August 8, 2022 Share Posted August 8, 2022 has anyone installed a Wax Valve on a 2003 Signature or similar with a Cummins ISX 525HP. If so, how did it work out Link to comment Share on other sites More sharing options...
Tom Cherry Posted August 8, 2022 Share Posted August 8, 2022 Just now, Rob M cKeown said: has anyone installed a Wax Valve on a 2003 Signature or similar with a Cummins ISX 525HP. If so, how did it work out Contact Source Engineering. I cannot recall what their website is called now….they renamed it a long time ago. They are the number one, at least here and on the original Yahoo site, company that had a complete kit. Two Ex Monaco folks….backgrounds were upper level Engineering and Warranty. Their forte was suspensions, but they also were the leading authority on the conversion back to simplicity. Our resident expert passed away, but he found that the valve or the controller was mounted upside down and prone to corrosion in the connector. Others might chime in, but some have cleaned the connections and rotated it 180 deg and never had another issue. Source is the one that has the complete retro kit and no one has ever complained about any performance or drivability issues…. Scott and Jim were their names….and the rest is lost in my fuzzy brain hard drive… Link to comment Share on other sites More sharing options...
vito.a Posted August 8, 2022 Share Posted August 8, 2022 (edited) Yes. I purchased the adjustable wax valve and installed it. It's working great. Had to remove the steel radiator pipe and weld the bung into it. My fan was previously running wide open and overworking the hydraulic system. Whitehouse Products in England has them very reasonable and surprisingly fast shipping. Edited August 8, 2022 by vito.a Link to comment Share on other sites More sharing options...
jacwjames Posted August 8, 2022 Share Posted August 8, 2022 This is the Source Eng kit Tom is suggesting. http://sourcerv.com/conversion But you might also check your radiator to see if there is a port in the top upper rear area, that is where my thermovalve is located. It then has two #4 hoses going to the fan speed switch that controls the speed. Link to comment Share on other sites More sharing options...
Tom Cherry Posted August 8, 2022 Share Posted August 8, 2022 17 minutes ago, jacwjames said: This is the Source Eng kit Tom is suggesting. http://sourcerv.com/conversion But you might also check your radiator to see if there is a port in the top upper rear area, that is where my thermovalve is located. It then has two #4 hoses going to the fan speed switch that controls the speed. The kit, I hope they are suppling should have a new thermostat cover or “gooseneck” with a tapped outlet. The original made you take your housing to a machine shop and have them do that. Many of us suggested that…. BTW, my discussions are from many years ago, but the basics are there and doing a little work on your own system, assuming it is often a connection issue fixed a lot of rigs. Link to comment Share on other sites More sharing options...
Chad A Posted August 8, 2022 Share Posted August 8, 2022 I had it done a year ago. Has been amazing. My fan was running wide open for no apparent reason. Would work fine for a half hour and then run for an hour, maybe 2 or 3, then would go back to normal. The fan running killed my mileage, made it hard to use the exhaust brake because it performed so differently, and was annoying as all get out because of how loud it was. Wax valve fixed it all. I took it to premier rv in junction city and I am pretty sure they sent it to Source to get fixed. Good investment. Link to comment Share on other sites More sharing options...
Mark Holt Posted August 8, 2022 Share Posted August 8, 2022 worth every Nickle I spent on it. Source Engineering knows there stuff Link to comment Share on other sites More sharing options...
Rob M cKeown Posted August 8, 2022 Author Share Posted August 8, 2022 Thanks for the responses, I have the Wax Valve and will get the fittings required to install it at the earliest opportunity. Link to comment Share on other sites More sharing options...
vito.a Posted August 8, 2022 Share Posted August 8, 2022 (edited) Picture of my install. I used some adapter fittings but was able to reuse both hoses. You can see the original electronic controller in the upper left. Link to great information on wax valve: https://www.irv2.com/forums/f115/fan-stuck-wide-open-376611.html Edited August 8, 2022 by vito.a Link to comment Share on other sites More sharing options...
WCourand Posted August 8, 2022 Share Posted August 8, 2022 Had one installed on our 2007 Executive last year at Source Engineering. Unit works great, nice upgrade. Several members of our Monaco chapter have had them installed in the past year and everyone is very satisfied with the results. Link to comment Share on other sites More sharing options...
