Larry Maida Posted August 9, 2022 Share Posted August 9, 2022 Hi All I am looking for the water filter by-pass cap for an Everpure under sink water filter. Might anyone have it and want to sell it? Link to comment Share on other sites More sharing options...
Dr4Film Posted August 9, 2022 Share Posted August 9, 2022 The Everpure Water Filter was always a PIA to deal with. I ended up removing the entire fixture and put together a bypass made out of parts I purchased at Lowes or Home Depot. Then later I installed an Ice Maker Water Filter into the Ice Maker water supply line. Photos below. Link to comment Share on other sites More sharing options...
Larry Maida Posted August 10, 2022 Author Share Posted August 10, 2022 You are quite talented. I havent had a bad time with it but never got the bypass cap when I bought coach. I thought before I change out the system I would see if I could aquire the cap to help when I needed to winterize it. Thank you for your response. Link to comment Share on other sites More sharing options...
Dr4Film Posted August 10, 2022 Share Posted August 10, 2022 Other than the Everpure being a PIA plus the filters were expensive, I also had an exterior water filter on my incoming water line, so I really didn't need the Everpure system. Changing the filter cartridge in the Whole House Water Filter was easier and cheaper too. In the photos you can also see the Insta-Hot System which I also removed and tossed into the trash one day when I was switching out the kitchen faucet. Waste of space on the counter. That opening now has a soap dispenser in it. Link to comment Share on other sites More sharing options...
jacwjames Posted August 10, 2022 Share Posted August 10, 2022 I kept my Everpure system. Since we don't full time changing the filter every season isn't that big of deal. Here is about the best price I found on the plug https://www.freshwatersystems.com/products/everpure-header-bypass-plug-assembly In the literature I had read there is a pressure limit and cautions not to use it under high pressure, what ever that means. Looking at it the weakest point was the hollow part of the plug so I got creative and used a piece of PVC pipe with a cap on it and epoxied in the hollow part to strengthen it. I left about 3" of PVC sticking out which actually helps installing and removing. But Richard is correct, if you use a lot of water it might be better to install a whole house duel filter system, one for sediment and the other for removing chemicals etc. Link to comment Share on other sites More sharing options...
Larry Maida Posted August 11, 2022 Author Share Posted August 11, 2022 Thank you both. Link to comment Share on other sites More sharing options...
