Lolo1034 Posted August 20, 2022 Author Share Posted August 20, 2022 So, we're on the road now, and when I have the generator running with the A/C, I can't connect to the fridge. I can hear the panel clicking and the A/C will intermittently shut off. Also, when hooked up to 50amp shore, I have A/C running and still can't connect fridge to the AC circuit. Any ideas?? Link to comment Share on other sites More sharing options...
Ivan K Posted August 20, 2022 Share Posted August 20, 2022 Lee, are you certain that the generator starts off your house batteries? I only have 4 house batteries so it could be different for you but 12.7V is a charged battery and should have started the gen if in fact is wired that way. Link to comment Share on other sites More sharing options...
Lee Smith Posted August 20, 2022 Share Posted August 20, 2022 Really not sure as I have not traced the wire diagram out. However, I do know that the generator "clicks at 12.7 volts" and starts at anything over that. Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted August 20, 2022 Share Posted August 20, 2022 Difficulty starting the big 12k generators was a topic occasionally on the old Yahoo group. As I recall the cause was deemed to be the cables were too small for such a long run. The fix that some resorted to was a bettery installed up front at the generator. I think it was wired to the existing cables, that way it fed full 12 volts to the gen and was charged along with the other batteries. Link to comment Share on other sites More sharing options...
Tom Cherry Posted August 20, 2022 Share Posted August 20, 2022 Similar issues in 2015. Genny would NOT start from almost new, fully charged House Trojans, First, verify WHICH bank, probably House. After a long time playing with my VOM and such…it was NOT a battery issue, but a cable issue. Now, once I jump started the Genny from the Yukon, all was well. Start easy and eliminate the simple ones. There are two ground studs behind or near the battery box area. One is HOUSE and other is CHASSIS. Loosen the nuts, barely, until you can rotate the cables side to side but still have friction of contacts. NOW if they are crappy and corroded or such, pull off and clean. If you rotate or twist side to side you clean and polish the connectors. The. Retighten. Go up front and shinny under Genny. Loosen the cables and rotate or twist and retighten. CAUTION. These are brass or copper, not a steel stud. Use common sense and don’t just assume they are loose and “crank down on the nuts”….folks have sheared a stud. Next, there will be, I think, a terminal on the positive side….follow the positive and tighten any stud connection. If the Genny goes directly to a chassis stud, do the same or trace the ground and make sure it is clean and tight. NOW try to start the Genny. That fixed mine and the grounds being loose are a common failure from road vibration. If NOT, use Jumper cables and start the Genny. Look for error codes when it shuts down. Download the manual and read the codes abs the suggestions. Post back after you do the above. 11 minutes ago, Ray Davis said: Difficulty starting the big 12k generators was a topic occasionally on the old Yahoo group. As I recall the cause was deemed to be the cables were too small for such a long run. The fix that some resorted to was a bettery installed up front at the generator. I think it was wired to the existing cables, that way it fed full 12 volts to the gen and was charged along with the other batteries. Correct, but a lot were bad Cable ends on the battery cables or ground issues. Too small cables was easier fixed with an up front battery rather 5han a massive recabling. 1 Link to comment Share on other sites More sharing options...
Paul J A Posted August 20, 2022 Share Posted August 20, 2022 50 minutes ago, Ray Davis said: Difficulty starting the big 12k generators was a topic occasionally on the old Yahoo group. As I recall the cause was deemed to be the cables were too small for such a long run. The fix that some resorted to was a bettery installed up front at the generator. I think it was wired to the existing cables, that way it fed full 12 volts to the gen and was charged along with the other batteries. Select a Motorcycle battery wth the appropriate CCA and install up front by Genny. Get power for that from FRB. I am not a "sparky", but people have done it. Eliminate that 40' run of cable for power to start Genny. A voltage regulator in the power line from FRB. And fused . Link to comment Share on other sites More sharing options...
CaptPat Posted August 24, 2022 Share Posted August 24, 2022 In 2013 I shifted to Lifeline AGM batteries, they served well and now need replacement. I’m going with Trojan T105’s as Lifeline AGM’s are now nearly $500 per battery, the difference in cost will pay for a lot of distilled water. Link to comment Share on other sites More sharing options...
