Guest rangerboat Posted August 16, 2022 Share Posted August 16, 2022 Have noticed that the batteries are receiving 17, 18 and once up to 19 volts on the house batteries, when I'm not connected to shore power. I've disconnected the leads from the Heliotrope as I am thinking the solar controller on the Heliotrope has gone bad. The house batteries are alone now without external charge. I have connected to shore power and they are reading 13.6v and holding. I did not disconnect the starting batteries and they are appearing OK when still plugged in and they were holding around 12.6-12.8v when on the Heliotrope. Is it possible that one side (the house side) of the Heliotrope has gone bad. If so, is there a repair possible or, is there are reasonably priced replacement for the Heliotrope? Help! Malcolm & Barbara, 2004 Monaco Dynasty; currently in Waynesville, NV Link to comment Share on other sites More sharing options...
vito.a Posted August 16, 2022 Share Posted August 16, 2022 I also had an issue with it overcharging. I turned off the equalization mode and that seems to have helped. Link to comment Share on other sites More sharing options...
Guest rangerboat Posted August 16, 2022 Share Posted August 16, 2022 Thanks Vito. I'll have a look at that. Link to comment Share on other sites More sharing options...
Old Dog Posted August 17, 2022 Share Posted August 17, 2022 If I remember correctly the output is adjustable. Download the manual and see if it will adjust before giving up on it. I talked with someone who was involved with designing them and by all accounts they are pretty reliable. The original setup wasn't meant to do anything beyond a trickle charge. Conductors were to small, too long and only a 100 watt panel. Link to comment Share on other sites More sharing options...
Guest rangerboat Posted August 17, 2022 Share Posted August 17, 2022 Thanks old Dog. Do you know where I can find a manual? Link to comment Share on other sites More sharing options...
jacwjames Posted August 17, 2022 Share Posted August 17, 2022 This might be a link to a manual http://beaveramb.org/forum/index.php?action=dlattach;topic=6283.0;attach=5396 Link to comment Share on other sites More sharing options...
Old Dog Posted August 17, 2022 Share Posted August 17, 2022 Just do a Google search using Helotrope 45d Solar Charge Controller Manual, thats how I found it. If you can't find it, I'm pretty sure the adjustment potentiometers are labeled. If these fail I can't see them failing in a overcharge state, they usually have no output. Link to comment Share on other sites More sharing options...
vito.a Posted August 17, 2022 Share Posted August 17, 2022 (edited) Helitrope manual. The settings are changed by moving jumpers. The first time I changed settings I had to remove it from the basement ceiling to see the jumpers and pins. Helitrope-RV45D-Solar-Panel-Manual.pdf Edited August 17, 2022 by vito.a Link to comment Share on other sites More sharing options...
Old Dog Posted August 17, 2022 Share Posted August 17, 2022 It's all coming back to me, been 5 years since I looked at mine. My memory is more of a sieve these days. Link to comment Share on other sites More sharing options...
Rocketman3 Posted August 17, 2022 Share Posted August 17, 2022 I wanted more solar on my roof…. I had already added 800w and another solar charge controller and wires and wanted more. So I pulled off the old panel (it was 85w if I remember correctly) and put on two 210w panels wired in series, I pulled the Helitrope and put in a Victron mppt 100/30 smart solar charge controller. I just reused all the same wires(disconnected the one going to the chassis battery). Easy change. To cover the hole where I removed the old panel, I got a piece of plexiglass- painted the back with black spay paint and put it over the hole. On my rig, the old wires were very large 8ga, so they will handle the 30amps of charging very well. Just an idea if you decide to replace the Helitrope and up your solar. (1220w of solar is very nice for boondocking). Link to comment Share on other sites More sharing options...
Guest rangerboat Posted August 17, 2022 Share Posted August 17, 2022 Thanks Rocketman, Old Dog, jacwjames and Vito.a, especially Vito for the manual. I'll check them all out. You guys are TERRIFIC! I can certainly relate to the memory challenges! Link to comment Share on other sites More sharing options...
Jdw12345 Posted August 17, 2022 Share Posted August 17, 2022 I experienced this same issue a couple of weeks ago on vacation and I’m wondering what to do, thanks for posting all of this! Link to comment Share on other sites More sharing options...
Ivan K Posted August 17, 2022 Share Posted August 17, 2022 I left the old Heliotrope controller above fridge in place and have it to charge chassis batteries only. It does good job at that. The old panel was relocated to have more space for 4 or eventually more new house panels. Connected the existing 8Ga house charging wires with a disconnect swich to new panels and use them to get high PV voltage down to a Victron 150/70 controller located next to inverter. Works great. The old controller has dip switches to adjust voltage. Link to comment Share on other sites More sharing options...
Guest rangerboat Posted August 17, 2022 Share Posted August 17, 2022 Thanks Ivan. Will look at your suggestion down the road but first, going to check out Ops Manual for the Heliotrope. Link to comment Share on other sites More sharing options...
Jdw12345 Posted September 19, 2022 Share Posted September 19, 2022 Rangerboat, just curious if you have made any progress on your controller? We’re back out in the coach for a week and yesterday I was showing 21 volts on the Aladdin screen, just wondering if I should disconnect my controller till we get home? Thanks in advance. Link to comment Share on other sites More sharing options...
Guest rangerboat Posted September 19, 2022 Share Posted September 19, 2022 I disconnected the feed into the heliotrope and it remains that way. Couldn’t find anyone that really understands the system. That disconnect is only for the house batteries. The starting batteries have always appeared okay. That’s the weird part. When we get home I’m going to take the unit out and put it on the bench for a real close look. please keep me posted on your situation. Link to comment Share on other sites More sharing options...
Jdw12345 Posted September 19, 2022 Share Posted September 19, 2022 (edited) So you disconnected the feed from the solar panel into the controller, is that correct? I’m assuming that I’ll, have to cover the feed line because there’s energy coming from the panel? Edited September 19, 2022 by Jdw12345 Link to comment Share on other sites More sharing options...
Guest rangerboat Posted September 19, 2022 Share Posted September 19, 2022 Yes, but only for the house batteries. I’ll do my best to attach a photo by end of the day Tape the ends Link to comment Share on other sites More sharing options...
Guest rangerboat Posted September 19, 2022 Share Posted September 19, 2022 Let me know if you can view. Also, PLEASE let me know if you solve the problem. Link to comment Share on other sites More sharing options...
Jdw12345 Posted September 20, 2022 Share Posted September 20, 2022 So I changed the dip switch settings, number 1 off 2 on 3 on 4 on i have AGM house batteries which doesn’t see correct according to the manual, but it was the way the previous owner had it set, when I read the manual that was posted above I set the dip switch’s according the the manual, so I switched the switch’s back the the previous owners settings, the batteries are 8 years old so I can only assume that the settings will work. My voltage did drop down to 14.5 so I’m guessing it nut have worked with this coach. Until I have any issues I’ll probably just leave it alone, that’s all I know now. My coach, while not in use, sits in my climate controlled building and plugged into shore power and no solar inputs. Thanks for your pictures! Link to comment Share on other sites More sharing options...
