Chargerman Posted August 17, 2022 Share Posted August 17, 2022 I am looking for the Bilstein shock numbers to fit an 06 RR10S chassis. I searched the forum but can’t track it down. If someone could share the correct part numbers I would appreciate it. I am looking for stock Bilstein numbers and not the Source ones Thanks in advance for your help! Link to comment Share on other sites More sharing options...
Ivan K Posted August 17, 2022 Share Posted August 17, 2022 Steven, I found ours here and they were correct and had best price back in 2017, of course they were about half today's price too. https://www.shockwarehouse.com/index.cfm?selected_make=Monaco+Roadmaster&selected_model=30544&selected_year=2006&mode=results Link to comment Share on other sites More sharing options...
Chargerman Posted August 17, 2022 Author Share Posted August 17, 2022 Thanks for the quick reply Ivan. I’ll take a look. I see they list 24-187312 but it’s a little confusing. Am I correct that the shock is the same for all positions? Link to comment Share on other sites More sharing options...
Ivan K Posted August 18, 2022 Share Posted August 18, 2022 They were all the same for me, 2000 S10 chassis. Link to comment Share on other sites More sharing options...
vito.a Posted August 18, 2022 Share Posted August 18, 2022 (edited) RR10S Roadmaster chassis uses Bilstein part number 24-187312, 10 each, (4 on front axle, 4 on drive axle, and 2 on tag axle). Bilstein uses the same shock front and rear.These are the new Comfort Valve versions with some design changes from the original. I purchased mine from Amazon. Many of us are using Bilstein on the rear and Koni on the front. The front Koni shocks take the big hit out of bridge abutments but cost more. Post # 26 has detailed steps on changing the rear shocks. Broken upper shock mounting stud, drivers side rear drive axle - Page 2 - iRV2 Forums Edited August 18, 2022 by vito.a Link to comment Share on other sites More sharing options...
Chargerman Posted August 18, 2022 Author Share Posted August 18, 2022 Super. Thanks Guys! Link to comment Share on other sites More sharing options...
RBRODDER Posted August 18, 2022 Share Posted August 18, 2022 (edited) If you get the correct part number, I found that RockAuto had the best prices earlier this year when I changed mine on a R4R chassis. Edited August 22, 2022 by RBRODDER Grammar Link to comment Share on other sites More sharing options...
