Monaco La Palma 32s Jacks... Control Panel by Driver window works
When did you last replace the ATF? It should be every 2 or 3 years. Videos on Youtube explain the process.
Check that with the jacks fully retracted that the oil reservoir is full (between 1/2 and 1/4” from the top). If not, add ATF fluid.
If you still have a a problem and it is a Power Gear leveling system, call Lippert support (lci1.com). I found them to be very helpful and knowledgeable.
So i just did a diagnosis on a hwh unit doing the same thing, im waiting on parts but ultamatly what i found is there are two power solinoids mounted to the motor with a band clamp, i followed the power wire going away from them and there was a in line fuse with a 40 amp fuse in it. The fuse holder was all melted and fuse was distorted. Testing shows there was power before the fuse but nothing going out of it, plus when i tried to remove that wire from the solinoid the terminil broke off. HWH still sell parts for there models so now im just waiting on them
  • 2 weeks later...
I am looking for my controller for the hydraulic leveling system, have not found it as of yet, Jack are not and have not been working properly. Where o where might it be, wires from the touch pad and pump etc seem to just disappear into the coach.
