mschfmkrs1 Posted September 1, 2022 Share Posted September 1, 2022 Does anyone have a source for the larger 5 inch exhaust "chrome tailpipe" to fit Monaco Signature? Thank you, Ed Hildebrand Link to comment Share on other sites More sharing options...
Dr4Film Posted September 1, 2022 Share Posted September 1, 2022 There are some vendors in the 2022 Monacoers Parts List. Link to comment Share on other sites More sharing options...
Tom Cherry Posted September 1, 2022 Share Posted September 1, 2022 Are you trying to find the “heat shield” SS outer cover which as been known, quite frequently, to break loose or do you need the physical exhaust pipe? Based on many past posts, these were custom fabricated for Monaco and were engine and maybe model specific. Monaco also changed them from year to year. A friend’s 2008 Dynasty if different from my 2009 Camelot, even though we have the exact same ISL and Diesel Particulate Filter. His is welded differently and has different “tab” or the bent offset sections. He has had to tack weld his twice and mine is as solid as the day it left the factory. Now having said that, our “decorative” cover is a protective device to keep the actual exhaust pipe away from the body or any dry vegetation. please edit the title to include the year….that helps get you more specific info. Richard gave you a lead on the Parts List. Many have purchased heavy gauge or SS pipes that were several inches longer. Then saw cut them and left 2, 3 or 4 long tabs. Then put a 90 deg Bend or an angled or tapered bend so the the tabs or fingers now had the same diameter as the real exhaust pipe. The can be attached with muffler clamps or spot welded on or “fabricated” by a custom muffler and exhaust shop. In most cases, you want a straight pipe on the end with not cutesy curved edge. You then saw it to the same angle as the tail pipe. There was nothing magical or engineered about them. GOOD LUCK. When you get it fabricated and attached, post a picture. If you find an exact match or something that worked with a little effort, send @Frank McElroy the vendor and part number. Thanks Link to comment Share on other sites More sharing options...
mschfmkrs1 Posted September 1, 2022 Author Share Posted September 1, 2022 Just needed a replacement 5" chrome exhaust tip for 2004 Monaco Signature with 60 series. I will post my findings. Thank you all for the parts list suggestion, great resource. Ed Hildebrand Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 1, 2022 Share Posted September 1, 2022 Many exhaust and tail pipe shops has them. Link to comment Share on other sites More sharing options...
streetrodder Posted September 1, 2022 Share Posted September 1, 2022 1 hour ago, mschfmkrs1 said: Does anyone have a source for the larger 5 inch exhaust "chrome tailpipe" to fit Monaco Signature? Thank you, Ed Hildebrand IOWA80.com Link to comment Share on other sites More sharing options...
Neil Loveless Posted September 1, 2022 Share Posted September 1, 2022 Ed, I recently order one for my Beaver from Amazon: Upower Diesel Exhaust Tip 5" Inlet/Outlet 16" Long Turn Down Exhaust Tip 304 Stainless Steel Bolt-On 5 inch Turn Down Tail Pipe Tips Visit the Upower Store 4.5 out of 5 stars 174 ratings $74.99 Link to comment Share on other sites More sharing options...
Jdw12345 Posted September 1, 2022 Share Posted September 1, 2022 I’m looking for one also, the previous owner kinda buggered this one up. Link to comment Share on other sites More sharing options...
Paul A. Posted September 1, 2022 Share Posted September 1, 2022 TRY these guys; https://www.4statetrucks.com/exhaust/semi-truck-5-inch-od-chrome-curve-turn-exhaust-stack_203266.asp?childskumatch=09-08501807&gclid=EAIaIQobChMI8-7W0sf0-QIV2P_jBx2ZkAEfEAQYASABEgLX2_D_BwE Link to comment Share on other sites More sharing options...
Paul Busch Posted September 1, 2022 Share Posted September 1, 2022 I got a 20” one from Napa. Took a day to get it. Cut it down and all is well. Link to comment Share on other sites More sharing options...
