Burgboy Posted September 12, 2022 Author Share Posted September 12, 2022 58 minutes ago, jacwjames said: OK, Can you feel if the floor is still wet?? The water damage could be old as far was when it got wet, unfortunately this type of flooring will not dry out but basically disintegrate. You can repair it, just takes time and $$. But you need to find out why the water pump is cycling, look in all the basement compartments and see if you can find any signs of dampness or water. If the pump is cycling it's going somewhere. Yep its definitely wet, i think im taking a saw to it next weekend unless anyone has any idea where the leak might be otherwise. The hose fitting behind the fridge seems to be in the floor Link to comment Share on other sites More sharing options...
jacwjames Posted September 12, 2022 Share Posted September 12, 2022 As you start taking out the old flooring work your way toward the leak, definitely have to repair otherwise you'll be fixing again. Link to comment Share on other sites More sharing options...
FLynes Posted September 12, 2022 Share Posted September 12, 2022 (edited) 3 hours ago, Burgboy said: Yep its definitely wet, i think im taking a saw to it next weekend unless anyone has any idea where the leak might be otherwise. The hose fitting behind the fridge seems to be in the floor Sorry, I was extremely busy today and couldn't respond until now. My supply hose for the ice maker, which is a white, opaque plastic line, is located under the fridge, in that furnace intake area, on the left side. There is also a shutoff valve on that line, in that same furnace intake area, which I closed. Edited September 12, 2022 by FLynes Link to comment Share on other sites More sharing options...
