Headlight Switch
NAMVET77
 Share
I have a 2004 Camelot that does not have any lights on my instruments.  I have traced it to the headlight switch.  Removed the switch (what a pain) and the only identifying numbers on the switch are 1503.  Parts store said it converts to SW132.  That is not the same switch.  Anyone have an idea what the part number is or what truck the headlights or tail lights came from? ☹️
Don
Don
Download the parts list.  Look there.  There are several different ones.
do a search and use headlight.  10 pages.  You have to be patient.  Here is one older post.
https://www.monacoers.org/topic/1947-2005-monaco-signature-headlight-switch/
Might be a Delco 1588….
https://www.autozone.com/electrical-and-lighting/headlight-switch/p/acdelco-switch-d1588/919149_0_0
good luck
22 hours ago, jacwjames said:
This is what fit on my 2002 Windsor
https://www.amazon.com/gp/product/B000C9SAJC/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
There was also a fuse in Monaco #1 box in my drivers side electrical bay, it was labeled Key SW Feed   a 10 amp fuse.
You can buy these at local auto parts store.
Just purchased this on Amazon and it is a perfect fit for my '03 Windsor.  Least expensive from the many sources that I checked.
Edited by michaelivan
Thanks for all the info.  I found the switch  at O'reilly's part store for $22 dollars.  It is a MasterPro Switch P/N 2HLS6.  Hopefully it last as long as the last one.  You guys are AWESOME!!!!!
Don Genesse
 Share
