TOBYLB4 Posted September 13, 2022 Share Posted September 13, 2022 2007 Monaco Dynasty. Coach is leaning to passenger side in Travel Mode. Touch pad shows it's level. I've looked thur the files didn't find anything on this topic. No air leaks levels up in Auto Mode. Is this a linkage problem? Any good video's of servicing the power gear system? Link to comment Share on other sites More sharing options...
vito.a Posted September 13, 2022 Share Posted September 13, 2022 Check your rear ride height sensors. They have a rubber grommet that deteriorate. First, air it up all the way so you can see under it. Then block it up for safety. Link to comment Share on other sites More sharing options...
Nevada Rob Posted September 13, 2022 Share Posted September 13, 2022 My first suggestion would be the rear ride height rod/adjustment. Easy fix. Move rod up for up and down for down. Mine was sagging 2.5 inches on the drivers side after replacing all 10 bags. Leveled it up to a 9" bag height measured from bag mounting plate to plate. Link to comment Share on other sites More sharing options...
Frank McElroy Posted September 13, 2022 Share Posted September 13, 2022 Likely the problem is with your drive axle ride height adjustment. The link below should provide you with useful information. Link to comment Share on other sites More sharing options...
