Carl Michael Posted September 14, 2022 Share Posted September 14, 2022 Looking at the wire diagram for camera tv connection, there is a converter between the camera and display unit. Does anyone know where it is located? 2000 signature Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 14, 2022 Share Posted September 14, 2022 On the 2004 Windsor the converter adapter is located on the back of the Sony monitor where the input jacks are. Link to comment Share on other sites More sharing options...
bobdinsmore Posted September 14, 2022 Share Posted September 14, 2022 On my 2000 Diplomat it's located in the console left of the driver. Link to comment Share on other sites More sharing options...
LakeBob Posted September 14, 2022 Share Posted September 14, 2022 On my 2009 Dynasty the video components are located on drivers side, accessed through the removable panel in front of the driver. I have three Sony video cable to RCA converters that feed an rca cable into primary intellitech module. My inside camera has an RCA output and plugs into the primary module. Link to comment Share on other sites More sharing options...
Ivan K Posted September 15, 2022 Share Posted September 15, 2022 Since you have a 00 Sig like we do, ours was just loosely sitting amongst all the wire bundles under the top dash cover. One S-video type cable in, one RCA video cable out, a little square metal box. Link to comment Share on other sites More sharing options...
Carl Michael Posted September 28, 2022 Author Share Posted September 28, 2022 Thanks everyone for your input. I ran a new wire to the camera. Carl Link to comment Share on other sites More sharing options...
bobdinsmore Posted October 1, 2022 Share Posted October 1, 2022 Carl, hwhat is your cale routing for the new cable? I could not find a good routing on my 2000 Diplomat. Thanks. Link to comment Share on other sites More sharing options...
Carl Michael Posted October 3, 2022 Author Share Posted October 3, 2022 Starting at the center basement compartment I used a 4 foot all thread quarter inch rod, taped the end of the new rca cable to the rod and going to the back over the aquahot heater following existing wireing, pushed the rod through the foam insulation around the wires far enough to find it going underneath the coach. From there followed existing wires to the back. Going forward, same thing taped the other end to the rod followed existing wires to the foam around the wires, pushed through the foam and found the rod under the front of the coach behind the front tires. Followed existing wires to the front behind drivers side headlight and again , this time using a coat hanger rather than the rod, went through the foam around the wires next to the left drivers foot location and into the dashboard area. Took a while. Many tight places under the coach. Hope this helps. Carl Link to comment Share on other sites More sharing options...
bobdinsmore Posted October 3, 2022 Share Posted October 3, 2022 Carl, thank you. Link to comment Share on other sites More sharing options...
