stahl_barry Posted May 9, 2020 Share Posted May 9, 2020 Hi, I have been engaging with my Dometic 510 Plus toilet for the last 2 days. I replaced the 2 seals between the bowl and pedestal and cleaned ball the with sealand cleanser. Put it back together and have not been able to stop it leaking, it is leaking out on the floor. I would appreciate any suggestions or ideas. I am thinking about replace the whole toilet, but my question is does it come preassembled? I do not want to go thru the samething if I need to put the bowl on. The toilet is 18 years old and I am thinking that the 2 plastic C clamps have lost their ability to squeeze the the bowl and pedestal tight enough to prevent it from leaking. Thanks Barry 2000 Diplomat Link to comment Share on other sites More sharing options...
Mel S - '96 Safari Posted May 9, 2020 Share Posted May 9, 2020 (edited) You can buy 46 minutes ago, stahl_barry said: Hi, I have been engaging with my Dometic 510 Plus toilet for the last 2 days. I replaced the 2 seals between the bowl and pedestal and cleaned ball the with sealand cleanser. Put it back together and have not been able to stop it leaking, it is leaking out on the floor. I would appreciate any suggestions or ideas. I am thinking about replace the whole toilet, but my question is does it come preassembled? I do not want to go thru the samething if I need to put the bowl on. The toilet is 18 years old and I am thinking that the 2 plastic C clamps have lost their ability to squeeze the the bowl and pedestal tight enough to prevent it from leaking. Thanks Barry, 2000 Diplomat Barry You can buy those "half clamps", (p/n 385310048), and any other Dometic 510 Plus toilet parts you might need, here: https://ardemco.com/traveler-toilet-model-510/ And from may other inline suppliers Edited May 9, 2020 by Mel S - '96 Safari typo Link to comment Share on other sites More sharing options...
Dwight Lindsey Posted May 9, 2020 Share Posted May 9, 2020 Barry: Are you sure it's leaking from the bowl to pedestal connection? I've had a leak at the gasket where the pedestal connects to the floor. I've replaced that gasket and carefully torqued the nuts tight without cracking the plastic. Problem solved. Go easy on those nuts. Dwight L 05 Knight Link to comment Share on other sites More sharing options...
stahl_barry Posted May 9, 2020 Author Share Posted May 9, 2020 Yes I can see the water running down from the top of the pedestal to the floor. Link to comment Share on other sites More sharing options...
Dwight Lindsey Posted May 9, 2020 Share Posted May 9, 2020 I'd take the bowl off again and make sure that the seals are correctly installed. Dwight L 05 Knight Link to comment Share on other sites More sharing options...
stahl_barry Posted May 9, 2020 Author Share Posted May 9, 2020 I have had bowl at least 6 times and reinstalled. The only thing I have noticed is that the black seal is not centered in the hole. That is what makes me think that the "C" clamps have distorted and not doing their job. 13 years is pretty old for plastic parts. Thank you for the thoughts. Oh by the way I am getting a order. Barry do you know if a new toilet comes completely assembled Barry Link to comment Share on other sites More sharing options...
bobdinsmore Posted May 10, 2020 Share Posted May 10, 2020 Barry, I had the same frustrating problem with my 510 toilet last year. I talked with someone at Dometic who gave me definite must-do's: - The split ring joins in the front, not on the side or the back, and the wide gap is centered in the back - The worm screw goes in the back covering the wide gap. - Do not over-tighten the worm screw, but definitely tighten it VERY firmly. I had made all three mistakes and found each of the above three steps absolutely crucial. It took me about a half dozen attempts which is frustrating and embarrassing. Check at minute 4:00 in this video for alignment of the parts: https://www.youtube.com/watch?v=ZNQjkfwBHx4 Link to comment Share on other sites More sharing options...
Mel S - '96 Safari Posted May 11, 2020 Share Posted May 11, 2020 (edited) 18 hours ago, bobdinsmore said: Barry, I had the same frustrating problem with my 510 toilet last year. I talked with someone at Dometic who gave me definite must-do's: - The split ring joins in the front, not on the side or the back, and the wide gap is centered in the back - The worm screw goes in the back covering the wide gap. - Do not over-tighten the worm screw, but definitely tighten it VERY firmly. I had made all three mistakes and found each of the above three steps absolutely crucial. It took me about a half dozen attempts which is frustrating and embarrassing. Check at minute 4:00 in this video for alignment of the parts: https://www.youtube.com/watch?v=ZNQjkfwBHx4 I believe that the specified torque, (aka: tightness), for that "worm gear band screw" is 65 in-lb, (INCH/pounds). , Edited May 11, 2020 by Mel S - '96 Safari Link to comment Share on other sites More sharing options...
