daveyjo Posted May 10, 2020 Share Posted May 10, 2020 I posted this a while ago and got no response, so I thought I would post it here. Someone posted recently that they had a slow moving bedroom slide and the solution was the wires connected to the motor were burned up or loose, and fixing it solved the problem. Easy-Peesy solution, right?😉 Their motor was at the top of their battery compartment. Well, that's not where it is for my 2005 HR Scepter.  I am looking for the curb side rear slideout motor. Anyone know where it is? Dave Jones Link to comment Share on other sites More sharing options...
Gary M Posted May 10, 2020 Share Posted May 10, 2020 Is it a cable slide? Mine is on wall above slide in wood accent box. Link to comment Share on other sites More sharing options...
Dale n Deb Posted May 11, 2020 Share Posted May 11, 2020 3 hours ago, daveyjo said: I posted this a while ago and got no response, so I thought I would post it here. Someone posted recently that they had a slow moving bedroom slide and the solution was the wires connected to the motor were burned up or loose, and fixing it solved the problem. Easy-Peesy solution, right?😉 Their motor was at the top of their battery compartment. Well, that's not where it is for my 2005 HR Scepter.  I am looking for the curb side rear slideout motor. Anyone know where it is? Dave Jones That is the only one we haven't found on ours. We haven't checked yet but wonder if it is under the area where the bottom drawers are located. Link to comment Share on other sites More sharing options...
Guest Timothy Posted May 11, 2020 Share Posted May 11, 2020 No, it should be at the top of the slide. Remove the facia at the top and you should have access to the motor Link to comment Share on other sites More sharing options...
Skier013 Posted May 11, 2020 Share Posted May 11, 2020 (edited) I had mine found over the rear tires. Had to remove the wheel well cover and look up. found a large mouse nest there also Edited May 11, 2020 by Skier013 Link to comment Share on other sites More sharing options...
Gary M Posted May 11, 2020 Share Posted May 11, 2020 A picture of your slide might help us if u haven’t found it yet! Link to comment Share on other sites More sharing options...
dl_racing427 Posted May 12, 2020 Share Posted May 12, 2020 20 hours ago, Skier013 said: I had mine found over the rear tires. Had to remove the wheel well cover and look up. found a large mouse nest there also The mouse nest was an aftermarket accessory. 😉 Link to comment Share on other sites More sharing options...
