Old Dog Posted September 21, 2022 Share Posted September 21, 2022 Looking for a part number/source of supply for the plastic support blocks that support the step cover when extended. Contacted Lippert and they sent me a blue print for the step cover assembly but it does not show this part anywhere and the Rep couldn't find it. Internet search has not turned up anything either. Don't know how helpful REV would be and I don't have a clue where else to get a replacement. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Solution Tom Cherry Posted September 21, 2022 Solution Share Posted September 21, 2022 WOW. bummer. I, too, did a little digging. I could not find anything on the internet. The step you have, MEMORY, if it is a double step, was recalled. https://lci-support-doc.s3.amazonaws.com/recall/ccd_0002553.pdf However, the date of 5/25/07 would have put the recalled units, more than likely, on the 08 units....just based on logistics. SOME could have been on the 07's... If Lippert doesn't have the parts, then I have no other ideas....other than to find a machine shop and have some made from metal and go from there. All the 3D printing might work....but if this is not a high demand item, then those individuals would probably not be involved. Pity Lippert does not provide the information on them. I did find the "Lippert Steps" parts page. and there are 91 items....but no support pieces nor included in the various sub assemblies. My question....did you go into Lippert PARTS within the Lippert System or did you go to Customer/Tech Support. I have found the parts folks know a LOT more. For whatever reason....and this is in the Hydraulic Slide domain, Lippert's OEM numbers....that they sold to Monaco....and put on the build sheets are NOT in the Tech Support data base. Get the Lippert PN from the step or your build sheet. Then go into Lippert Parts on the voice prompts. I finally was transferred from Slide Tech Support to Parts as the individual could NOT find my unit....since he only had the Aftermarket PN. Crazy....YES. But it was what the Parts Rep told me. The parts folks were quick to tell me exactly what I needed and VERY WELL INFORMED. Good Luck.... Link to comment Share on other sites More sharing options...
Old Dog Posted September 22, 2022 Author Share Posted September 22, 2022 Appreciate the reply however this is about the STEP WELL COVER, not the steps. Link to comment Share on other sites More sharing options...
Frank McElroy Posted September 22, 2022 Share Posted September 22, 2022 If you don't have a 3D printer to print your own replacement parts from the STL file in our downloads file, Contact Paul Whittle. I think he can help you. 1 Link to comment Share on other sites More sharing options...
Old Dog Posted September 22, 2022 Author Share Posted September 22, 2022 Appreciate the 3D Print option, is the "make your own replacement" the only option? Link to comment Share on other sites More sharing options...
Frank McElroy Posted September 22, 2022 Share Posted September 22, 2022 15 hours ago, Old Dog said: Appreciate the 3D Print option, is the "make your own replacement" the only option? Let's see if someone else replies, but the main reason why Paul took the time it takes to make an STL file and graciously sharing it with the group was to make a stronger replacement part. Offline, I sent Paul a message. I think he'll either post here or contact you. Link to comment Share on other sites More sharing options...
Old Dog Posted September 22, 2022 Author Share Posted September 22, 2022 Appreciate the assist, I'll call REV with the part name/number and see it they have any. If not I now have another option with the 3D file. Thx Link to comment Share on other sites More sharing options...
Old Dog Posted September 22, 2022 Author Share Posted September 22, 2022 REV website still had some so I'm going that option, thx to all. Link to comment Share on other sites More sharing options...
pwhittle Posted September 22, 2022 Share Posted September 22, 2022 Rev still sells the original design. Link is in the in post with the 3D file. I have had the 3D printed ones on for a few months now, and they are working well. Paul Link to comment Share on other sites More sharing options...
Tom Cherry Posted September 22, 2022 Share Posted September 22, 2022 9 hours ago, Old Dog said: REV website still had some so I'm going that option, thx to all. Don, Sorry for the confusion. That makes sense now. Could you expand a little on the Rev "OPTION". Did you find the Support Bracket on REV. Do you have a Part Number or REV item? I looked again and did not find the bumper or the support bracket or whatever the proper name is. If you get a part number or a link, please post it so Frank McElroy can add it to the Parts List. Thanks/ Link to comment Share on other sites More sharing options...
Frank McElroy Posted September 22, 2022 Share Posted September 22, 2022 38 minutes ago, Tom Cherry said: Don, Sorry for the confusion. That makes sense now. Could you expand a little on the Rev "OPTION". Did you find the Support Bracket on REV. Do you have a Part Number or REV item? I looked again and did not find the bumper or the support bracket or whatever the proper name is. If you get a part number or a link, please post it so Frank McElroy can add it to the Parts List. Thanks/ Tom, the part number is in the STL file description. Link to comment Share on other sites More sharing options...
Tom Cherry Posted September 22, 2022 Share Posted September 22, 2022 1 hour ago, Frank McElroy said: Tom, the part number is in the STL file description. Thanks....I figured that out.....BUT, for the REST of the posters. NEVER, EVER assume Monaco did things the same. Frank and I exchanged pictures. The step cover on the Dynasty (and above) is totally different from the Camelot. The Supports, as they are called, are NOT used on the Camelots (perhaps lower). I have NO plastic Support brackets of such on either side of the step well....as does the Dynasty, per Frank's photos. Here is the picture of the Camelot step cover....focused on the LEFT side. Frank's Dynasty is different. YES, our cover comes out....and at the end of the EXTEND travel, the single motor raises the Cover so it is flush with the tile floor. Mine is the last year (2008) of the Kwikee Dayton Single Motor unit. Kwikee went to the DUAL motors...same, probably, as the OUTSIDE Step Motors. Now WHY the step well cover stays UP and supports weight (my wife and I have stood on it - individually- on it all the time), I haven't a clue. The picture of the step itself shows the cover, when retracted, is about 2" lower....and the step itself if probably 6" high....or the carpet piece. Learned a LOT. Glad the poster got his new brackets. Paul's per Frank, are much stronger. NOW I know.... Colonel Duckwitz's comment about ASSUMING that there is only ONE type of "Whatever" on a Monaco MH is the fallacy that we all get into. Link to comment Share on other sites More sharing options...
hadarrowjr Posted September 23, 2022 Share Posted September 23, 2022 (edited) I may have the support blocks in my barn. I’ll check this morning. If anyone is still interested please send me a text at (803) 622-6610. I checked my barn and I have a set of the support blocks. Edited September 24, 2022 by hadarrowjr Link to comment Share on other sites More sharing options...
