barderd Posted September 24, 2022 Share Posted September 24, 2022 I have found some dead equipment or blown Fuses as a result of a lightning strike. The dead equipment ranges from satellite boxes, water pumps, tv,s phones. Etc my last fuse to replace is to check the AquaHot 100-4s,s fuse— if I can find it. Documentation says it is in the passenger rear run bay, the question is where? This is on a 2005 Windsor PAQ 40 ft. The AQUAHOT shows no power at the switches inside and no indicator lights on the wall mounted panel in the AquaHot bay. Power to the breaker in the bedroom shows good now. any thoughts as too location? Quote Link to comment Share on other sites More sharing options...
Tim-AZ Posted September 24, 2022 Share Posted September 24, 2022 There are plenty of fuses internal to the aqua hot also. Link to comment Share on other sites More sharing options...
Tom Cherry Posted September 24, 2022 Share Posted September 24, 2022 1 hour ago, barderd said: I have found some dead equipment or blown Fuses as a result of a lightning strike. The dead equipment ranges from satellite boxes, water pumps, tv,s phones. Etc my last fuse to replace is to check the AquaHot 100-4s,s fuse— if I can find it. Documentation says it is in the passenger rear run bay, the question is where? This is on a 2005 Windsor PAQ 40 ft. The AQUAHOT shows no power at the switches inside and no indicator lights on the wall mounted panel in the AquaHot bay. Power to the breaker in the bedroom shows good now. any thoughts as too location? Here is a file with the closest that I could find in the file search. I also extracted a PDF for the heating system. NOTE in the middle of the drawing, if you blow it us....there is a #8 gauge wire with incoming power for the whole system. I did not look elsewhere for how that is fused. There are 5 fuses showing for the various pumps and relays. That is about as much as I can contribute. Question for you....as Others might like to understand. You have listed both 12 VDC and 120 VAC items that have "Fuses" blown or are "injured and non responsive"....is that correct that the strike got BOTH sides of the circuits. if so YEOUCH.... This might be a claim for your comphrensive coverage....if you have it. Good Luck and keep up posted. Windsor Aquahot Wiring.pdf Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 24, 2022 Share Posted September 24, 2022 In the 2004 Windsor, the fuse in question is located under the battery maintainer. There are 4 fuses in a horizontal row. It is the first fuse on the right. They do not look like what one might call a normal fuse. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 25, 2022 Share Posted September 25, 2022 Chuck, I thought those were auto-resetting circuit breakers and not fuses as such. Photo attached. 1 Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 25, 2022 Share Posted September 25, 2022 You are correct, but we are dealing with a possible surge or lightning strike. I would swap the one with a known good working one to be sure. Link to comment Share on other sites More sharing options...
