Hugeshocker Posted September 29, 2022 Share Posted September 29, 2022 (edited) Inverter not charging batteries. Worked with Magnum tech support, diagnosed no power getting to inverter. Tech support suggest the inline 400 amp fuse was blown. I have a 2007 Holiday Rambler Imperial, any suggestion on where the fuse might be located? Tech support said by code it should be within 18 inches of the batteries. I cannot seem to find it. Thank you, Hugh Edited September 29, 2022 by Hugeshocker Link to comment Share on other sites More sharing options...
Seaplane Posted September 29, 2022 Share Posted September 29, 2022 Probably in the Rear Run Bay near the chassis and Coach shut off’s. Link to comment Share on other sites More sharing options...
Hugeshocker Posted September 29, 2022 Author Share Posted September 29, 2022 We have 8 coach batteries, I have checked both bays, cannot seem to locate the fuse. Not 100% sure what it looks like, other than google, but I don't see anything connected to the positive cables that looks like a fuse or a fuse holder. Link to comment Share on other sites More sharing options...
FishAR Posted September 29, 2022 Share Posted September 29, 2022 This is my rear electrical bay where I told you it was on facebook. Bottom right is the fuse. 1 Link to comment Share on other sites More sharing options...
Tom Cherry Posted September 30, 2022 Share Posted September 30, 2022 15 hours ago, FishAR said: This is my rear electrical bay where I told you it was on facebook. Bottom right is the fuse. LOOK CLOSELY. Blow up the Picture. Suggest you read the House or Coach Electrical Section of your manual. It does into detail about what you are searching for. The term "Fuse" is generic and the Magnum Tech has NO CLUE as to how Monaco "protected" the Inverter. There is, MEMORY, a bank of Resettable Circuit Breakers used on the Dynasty (and on up) instead of "Replaceable Fuses". Go into Amazon and put in 300 Amp 12 V Resettable Circuit breaker. That will show you a picture. The one in the lower corner is what the poster says.... Also, suggest that you start looking in the back of your manual at the wiring diagrams. You have a BUNCH of them...as well as "Self Resetting" Circuit Breakers. The Resettable has the LEVER. The Self Resetting will get hot....BLOW....then cool down. Good Luck. I changed the title to make it clearer what the issue is. In the future, use the Model and Year. It is suggested that you update your Profile to include the YEAR, Model, Floor Plan, etc. It makes it easier for someone to respond....as well as cuts down on the guessing.... Link to comment Share on other sites More sharing options...
Hugeshocker Posted September 30, 2022 Author Share Posted September 30, 2022 Thank you to everyone for their suggestions. Tom, the picture of the resettable circuit did the trick. we have several of those in the rear electrical panel. When I know what to look for, it became a 5 second job to use in the lever on the 2 circuits, and the inverter is now up and running/charging. Thank you again to everyone for the help! Hugh 1 Link to comment Share on other sites More sharing options...
Tom Cherry Posted October 1, 2022 Share Posted October 1, 2022 6 hours ago, Hugeshocker said: Thank you to everyone for their suggestions. Tom, the picture of the resettable circuit did the trick. we have several of those in the rear electrical panel. When I know what to look for, it became a 5 second job to use in the lever on the 2 circuits, and the inverter is now up and running/charging. Thank you again to everyone for the help! Hugh Cool. Always good when you find the solution Link to comment Share on other sites More sharing options...
