LakeBob Posted October 4, 2022 Share Posted October 4, 2022 I'm on the road and haven't had the time to dig into the forums and wiring diagrams, however, I'm having an issue with the above lights. Everything was working fine and then I dont have the step lights,, handles, porch or bay lights working. I believe these are all on the chassis?, not the house circuits. Tried resetting using the battery disconnect switches without success Any great insights before I roll up my sleeves and dig in tomorrow? Thanks!!! Link to comment Share on other sites More sharing options...
Dr4Film Posted October 4, 2022 Share Posted October 4, 2022 Start checking chassis fuses located in your FRB aka Front Run Bay. Check each one with a continuity meter set to tone. Check ALL of them regardless of what they are labeled as it may be under a fuse with an entirely different name or function. Link to comment Share on other sites More sharing options...
LakeBob Posted October 5, 2022 Author Share Posted October 5, 2022 Thanks. I did a full reset, disconnecting from shore power and cycling off the coach and house batteries and this fixed the problem. I believe this is all related to the solenoid and the salesman switch. . Link to comment Share on other sites More sharing options...
