thompson_skip Posted May 15, 2020 Posted May 15, 2020 I have several Dash gauges oN our 2003 Dynasty that have stopped working. Is there anyway to fix them
Steven P Posted May 23, 2020 Posted May 23, 2020 Have the lights stopped or the gauges themselves? If it's just the lights, you likely can replace the bulb in them w a new one. Can you post a pic and let us know? If it's the gauge, it may be a bad ground or sending wire. This pic has part of the back of my boost gauge. There is a black knob (cant see in pic) that you twist and pull out the bulb.
thompson_skip Posted May 23, 2020 Author Posted May 23, 2020 Thanks Steven. The gauges all work but they don’t light up. So I assume the bulb is bad. Sounds like I can replace the bulb if I can remove the gauge. Any idea how to remove the gauge?
Steven P Posted May 24, 2020 Posted May 24, 2020 Skip, Do you have the access panel on your dash above your steering wheel? If so, lift it up and you can see the backs of the gauges. You may not need to remove the gauges to change the bulbs. Look for the light. Mine are black and u twist 90 deg and pull out. If you have to remove the gauge, there are usually 2 brackets that hold them in. Pull off the 2 nuts, then brackets, then pull gauges out from the front. Good luck.
thompson_skip Posted May 24, 2020 Author Posted May 24, 2020 I have gotten into the access before, but didn’t know what to look for. I will give it another try. Thanks so much. 1
tdccmc Posted May 25, 2020 Posted May 25, 2020 On my 2008 Diplomat, I replaced the headlight switch and dash lights came on. Additional benefit and surprise, the toggle switch lights by entry door also came on. In my case all the dash lights were out. Tony
