FLynes Posted October 12, 2022 Share Posted October 12, 2022 Anyone ever have this happen to their coach? I’m thinking liquid nails is in this stove top counter’s future. Link to comment Share on other sites More sharing options...
gdroberson Posted October 12, 2022 Share Posted October 12, 2022 needs to be two part epoxy made for solid surface Link to comment Share on other sites More sharing options...
Ray Davis Posted October 12, 2022 Share Posted October 12, 2022 Maybe a wooden support from below, something like a cradle to support it then epoxy. Link to comment Share on other sites More sharing options...
Fasthobie16 Posted October 12, 2022 Share Posted October 12, 2022 (edited) Yes it did , while driving . Got to destination and got some wood and some sheetrock screws at the local lumber yard. Had a hacksaw and drill motor already. Old factory installation was glue only. Lasted 18 years. Did not want to go back with glue ( liquid nails).Braced the burner unit up from the bottom then installed four legs ( tightly) up against it. Screwed the legs to the shelf below diagonally which was carpeted. Had to cut legs a pinch longer than I measured. Trimmed till they fit good and tight against the unit and shelf. Still have lots of space there for storage even with the leg supports in place. Hasn’t moved in four years. It certainly won’t fall again. Easy and cheap fix. Didn’t glue. No need to. It’s solid. Jim 2000 Monaco Dynasty 40’ ’04 Liberty Toad Edited October 12, 2022 by Fasthobie16 Added info. 1 Link to comment Share on other sites More sharing options...
FLynes Posted October 12, 2022 Author Share Posted October 12, 2022 3 hours ago, gdroberson said: needs to be two part epoxy made for solid surface I’m one of those guys who, as a kid, always asked why. I’ve never had bad luck with Liquid Nails or Loctite PL Max…does it not adhere properly to the Corian? I definitely see and appreciate the benefit of bracing. Link to comment Share on other sites More sharing options...
gdroberson Posted October 12, 2022 Share Posted October 12, 2022 I have been doing solid surface tops for over 25 years and the only glue that will stick is the glue for solid surface and silicone if I where you I would contact a counter top co. and have them clean it and reglue it you clean it with denatured alcohol Link to comment Share on other sites More sharing options...
FLynes Posted October 12, 2022 Author Share Posted October 12, 2022 1 hour ago, gdroberson said: I have been doing solid surface tops for over 25 years and the only glue that will stick is the glue for solid surface and silicone if I where you I would contact a counter top co. and have them clean it and reglue it you clean it with denatured alcohol Denatured alcohol I do have. I'll contact a countertop place tomorrow. Thanks for the info. Link to comment Share on other sites More sharing options...
myrontruex Posted October 13, 2022 Share Posted October 13, 2022 Structural adhesive link Find a source for a small quantity of structural adhesive. It is a two part epoxy and incredibly strong. I built an airplane and used a lot of it. I think finding my gas top floundering like that would be a good time to install an induction top. Of course I will never do that on mine. I use portable induction units for all of our cooking and the stove top cover is always on leaving us much more counter space. The gas top is a great backup if needed. Just endured the hurricane and thought I might need the gas top to save generator fuel but we were one of the lucky ones with a very short power outage of just 48 hours. Link to comment Share on other sites More sharing options...
Tom Cherry Posted October 13, 2022 Share Posted October 13, 2022 12 minutes ago, myrontruex said: Structural adhesive link Find a source for a small quantity of structural adhesive. It is a two part epoxy and incredibly strong. I built an airplane and used a lot of it. I think finding my gas top floundering like that would be a good time to install an induction top. Of course I will never do that on mine. I use portable induction units for all of our cooking and the stove top cover is always on leaving us much more counter space. The gas top is a great backup if needed. Just endured the hurricane and thought I might need the gas top to save generator fuel but we were one of the lucky ones with a very short power outage of just 48 hours. From a user's point of view, Loctite PL is one of the best. I used it for the early Guardian plate installs as I had confidence in it. I have used it in many applications. If you use it, or ANY structural adhesive, you SHOULD keep the joint(s) clamped or under compression for 24 hours. Not critical on small items, but on larger or laminating items, a necessity. I spoke to Loctite Tech support and they said that any long runs where you were laminating or bonding two work pieces "COULD" have an erratic bead as the structural adhesives, or at least theirs, has a small exothermic expansion during curing. By clamping or using weights, you minimize that . You can buy Loctite PL in small tubes or standard size caulking tubes or the industrial sized caulking tubes. Link to comment Share on other sites More sharing options...
Notn2bars Posted October 13, 2022 Share Posted October 13, 2022 Had the same thing happen to our stove top. Used original JB Weld, easy fix. Figured it would work, as I repaired a cracked head on a v 6 in a GMC pickup back in the early 70's. Link to comment Share on other sites More sharing options...
amphi_sc Posted October 14, 2022 Share Posted October 14, 2022 Yes, mine started to drop too a few years ago. Can't remember exactly the "glue" I used but probably some sort of liquid nails, and used a couple of bottle jacks ( available 3 ton and 20 ton!!) to press it back up, then after overnight curing time, screwed in some wooden blocks to help hold it up long term and removed the jacks. Been okay now for a few (3-4????) years now. Perhaps a different glue would have been better to use but when on the road I used what ever HD or Lowes had available. 20 ton jack was definitely overkill but available... It was definitely a shocking scramble at the time. Link to comment Share on other sites More sharing options...
GNRACN Posted October 14, 2022 Share Posted October 14, 2022 What we have here is every acrylic solid surface fabricators worst nightmare! High heat cycling, thermal contraction and expansion of up to 1/8" when using in just the cook-top area. Then introduce vibration, flex and shock, the propensity for failure is very high. I am absolutly amazed of the durabilty and fabrication stands up to the riggers of RV use. I fabricated and innovated methods and techniques for most of the major brands of acrylic manufacturers and was certified in all of them. Look under the back of your countertop and should be able to see what brand it is or go and look at samples in cabinet, floor covering, home stores to determine the brand that you have by looking at patterns that match yours. I highly recomend using a qualified fabricator. Most major cities have someone who is the go to guy for the major manufactures for warranty repairs. Warranty on residential applications is like ten or twelve years depending on the brand. This is not a bad hair cut once you screw it up with the wrong repair, it doesn't grow out! I sold, fabricated, installed and yes occasionally repaired acrylic and laminate countertops for thirty five years. Good Luck with whatever you choose to do! Side note: Correct adhesive sets up in about an hour and has a open time of less then five minutes maximum!! Sorry about the length of comment. Link to comment Share on other sites More sharing options...
FLynes Posted October 14, 2022 Author Share Posted October 14, 2022 7 minutes ago, GNRACN said: What we have here is every acrylic solid surface fabricators worst nightmare! High heat cycling, thermal contraction and expansion of up to 1/8" when using in just the cook-top area. Then introduce vibration, flex and shock, the propensity for failure is very high. I am absolutly amazed of the durabilty and fabrication stands up to the riggers of RV use. I fabricated and innovated methods and techniques for most of the major brands of acrylic manufacturers and was certified in all of them. Look under the back of your countertop and should be able to see what brand it is or go and look at samples in cabinet, floor covering, home stores to determine the brand that you have by looking at patterns that match yours. I highly recomend using a qualified fabricator. Most major cities have someone who is the go to guy for the major manufactures for warranty repairs. Warranty on residential applications is like ten or twelve years depending on the brand. This is not a bad hair cut once you screw it up with the wrong repair, it doesn't grow out! I sold, fabricated, installed and yes occasionally repaired acrylic and laminate countertops for thirty five years. Good Luck with whatever you choose to do! Side note: Correct adhesive sets up in about an hour and has a open time of less then five minutes maximum!! Sorry about the length of comment. No, I completely appreciate it. So far I have contacted five different countertop places in my area and only one has a very slight glimmer of hope… While they will not come out and work on it, the secretary has put the word out to see if any technicians might be willing to do it on their day off as a side job. I’m not holding my breath, but we’ll see. Link to comment Share on other sites More sharing options...
