Guardian74 Posted October 19, 2022 Share Posted October 19, 2022 My DRL relay burned up and damaged the control board on my 2007 signature. Its also on the 2008 dynasty. Can someone assist with parts of part numbers? thanks Link to comment Share on other sites More sharing options...
cbr046 Posted October 19, 2022 Share Posted October 19, 2022 If you're not particular and decent at soldering you can add wire where the pc board traces were. The bigger question is: Why did the DRL relay burn up? Are you running higher amperage bulbs? - bob Link to comment Share on other sites More sharing options...
Guardian74 Posted October 19, 2022 Author Share Posted October 19, 2022 No, the RV was parked for 2 months. I was in it asleep and the smoke detector went off. I turned on the vents. I looked for the source. I couldn't find anything. I had all the windows and door open. I could smell it by the door. It was dark and I looked around and I finally found the burnt up relays. I read that the Hamsar solenoid is prone to burning up. If I would of known I would of pulled it. I don't think it was working because I don't remember the DRL's (day running lights) were not on. For those reading, pull or replace the relay when not driving. Link to comment Share on other sites More sharing options...
jacwjames Posted October 19, 2022 Share Posted October 19, 2022 (edited) Where do you live??? I think the DRL was installed to comply with Canadian rules. I have the DRL wiring harness but no relay was ever installed. When I'm getting ready to leave and going through the checks etc I try the windshield wipers to make sure they work. This automatically turns on my head lights. Might be a viable option of you want running lights. Edited October 19, 2022 by jacwjames Link to comment Share on other sites More sharing options...
Garry Donohue Posted October 19, 2022 Share Posted October 19, 2022 I got mine from Allied. Photo attached. I have a 2007 Dynasty. Link to comment Share on other sites More sharing options...
