rdetter5009 Posted November 2, 2022 Share Posted November 2, 2022 I have a slide cylinder with a very slow leak, it is the rear cylinder on the passenger side (sink micro cabinets ). It is inside the arm for extending and retracting, the bottom of the slide tube is wet with red hyd fluid, I know it's either a seal gone bad a hose or fitting leaking. What I need to know is the procedure to get in to look at it and how does the cylinder come out. Thank You Guys for any help. Bob Etter 2004 Holiday Rambler Navigator Link to comment Share on other sites More sharing options...
Ivan K Posted November 2, 2022 Share Posted November 2, 2022 Is this old post of any help? You don't say what make slideout system you have. Hydro fluid leak on main slide https://www.monacoers.org/topic/464-hydro-fluid-leak-on-main-slide/ Link to comment Share on other sites More sharing options...
