Woody O Posted November 21, 2022 Share Posted November 21, 2022 I have a 2006 Monaco Dynasty. I've noticed several times now that when I pull the headlight switch, all the lights come on except the headlights. Play with switch a little and the headlights come on. So, I went to parts list and all I saw was I think, a 1974 series headlight switch. So, has anyone replaced their switch in a 2006 coach? If so, do you still have the part number? Thanks, Woody O Link to comment Share on other sites More sharing options...
DavidL Posted November 21, 2022 Share Posted November 21, 2022 You might spray some WD40 into the switch and on / off / dimmer a bit to clean the contacts. If that doesn't work, then you will have the switch so you can take a picture or get a part number of of it for finding one. Link to comment Share on other sites More sharing options...
Tim-AZ Posted November 21, 2022 Share Posted November 21, 2022 Mine is a 78-84 chevy pickup or van 3/4 ton. I wired in a relay to just run the headlights after the factory one melted. Tim Link to comment Share on other sites More sharing options...
Bykerboy Posted November 22, 2022 Share Posted November 22, 2022 Replaced mine on my 2006 Monaco Knight. It is an OEM Chevrolet part: https://www.amazon.com/gp/product/B000C9SAJC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
wamcneil Posted November 22, 2022 Share Posted November 22, 2022 Before you start the work, watch a YouTube video on changing the Chevy switch. There’s a button on the switch housing to release the shaft that’s not super intuitive. And you’re working behind the dash without clear sight. Cheers Walter Link to comment Share on other sites More sharing options...
Solution VinceB Posted November 22, 2022 Solution Share Posted November 22, 2022 On 11/21/2022 at 6:12 AM, DavidL said: You might spray some WD40 into the switch and on / off / dimmer a bit to clean the contacts. If that doesn't work, then you will have the switch so you can take a picture or get a part number of of it for finding one. I'd go with spray contact cleaner - it won't leave an oily residue nor gather dust & lint, etc. Link to comment Share on other sites More sharing options...
