On_the_road Posted December 12, 2022 Share Posted December 12, 2022 2002 Monaco Signature General 45 VIN: 1RF12071021015858 73,000 miles. Cummins ISM 500 Hp engine, plenty of power for those Rocky Mountain passes. Allison 4000 MH 6 speed World transmission. 190 gallon fuel tank. Full air suspension for smooth ride. Good tires all around with no cracking. 2 Slides 360 view camera system with separate backup camera. Motorcycle carrier, it will carry your full dress Harley 10,000 LB tow hitch Toad attachment. Onan 12.5Kw generator with 3312 hours. Bose stereo KVH TracVision A9 Satellite receiver. AquaHot furnace. 3 roof heat pump / air conditioners. Beautiful cherry cabinets. Clean title. Medical issues force me to sell my beautiful motor home. I am in New Hampshire. 1 Link to comment Share on other sites More sharing options...
TDaleABQ Posted December 12, 2022 Share Posted December 12, 2022 how much? Link to comment Share on other sites More sharing options...
On_the_road Posted December 13, 2022 Author Share Posted December 13, 2022 I forgot to put the most important thing in my listing; the price! I am looking for $89,500. Link to comment Share on other sites More sharing options...
Paul A. Posted December 13, 2022 Share Posted December 13, 2022 15 hours ago, On_the_road said: I forgot to put the most important thing in my listing; the price! I am looking for $89,500. The specifications for your coach are not in a Monaco Sales brochure. Do you know the wheelbase dimmension? Link to comment Share on other sites More sharing options...
On_the_road Posted December 13, 2022 Author Share Posted December 13, 2022 I noticed that the brochure for 2002 only goes up to 42' in the specifications table. I went out and measured from the front axle to the tag axle and got 28' 6" or 342". It is 24' 10" or 298" to the drive axle. Here is the brochure and the window sticker for my Monaco. 02Signature.pdf Monaco_Signature_window_sticker.pdf Link to comment Share on other sites More sharing options...
Paul A. Posted December 13, 2022 Share Posted December 13, 2022 4 hours ago, On_the_road said: I noticed that the brochure for 2002 only goes up to 42' in the specifications table. I went out and measured from the front axle to the tag axle and got 28' 6" or 342". It is 24' 10" or 298" to the drive axle. Here is the brochure and the window sticker for my Monaco. 02Signature.pdf 1.48 MB · 6 downloads Monaco_Signature_window_sticker.pdf 52.23 kB · 10 downloads Thanks. I thouhgt it was 297". Here is a link for the 2000 Model you have. Very simular spec s. https://www.monacocoach.com/resources/media/user/1469214020_brc_pdf.pdf Link to comment Share on other sites More sharing options...
On_the_road Posted December 14, 2022 Author Share Posted December 14, 2022 I could be off by 1 inch on the wheelbase. There are a few differences between my 2002 and the 2000 that I can see from the brochure. My engine has a Jake break and not an exhaust brake. There is a switch to have the Jake break operate on 3 valves or on 6 valves. That changes the breaking force. I believe that it also has a transmission retarder. Link to comment Share on other sites More sharing options...
Ivan K Posted December 14, 2022 Share Posted December 14, 2022 There is plus $90K difference in yours compared to our 2000 base price. Same Jake as a standard, retarder would be nice if really there, did not think that Monaco used them. Nice coach you got! 1 Link to comment Share on other sites More sharing options...
On_the_road Posted December 14, 2022 Author Share Posted December 14, 2022 I read that there was a retarder, but I don't know how to confirm that it is there. What does it look like? I have looked at the exhaust manifold and I don't see anything that looks like an exhaust brake, there is no actuator that I can see. Link to comment Share on other sites More sharing options...
Ray Davis Posted December 14, 2022 Share Posted December 14, 2022 FWIW before this coach we owned an 99 Endeavor with a cat eng. My manual also mentioned a transmission retarder, I got excited looking for it so I asked Freightliner ( my chasssis ) . I showed them my manual, they scratched their heads & said they had never seen nor heard of one.. IRCC it is an impeller in a chamber inside the trans, when filled with oil it becomes a powerful brake, & generates massive amounts of heat. 1 Link to comment Share on other sites More sharing options...
On_the_road Posted December 14, 2022 Author Share Posted December 14, 2022 I have read about the retarder and assumed that it was something bolted onto the transmission. I would like to see pictures of what it looks like. Link to comment Share on other sites More sharing options...
Ivan K Posted December 14, 2022 Share Posted December 14, 2022 (edited) It would be an extension to the output side of transmission. Like this: Edited December 14, 2022 by Ivan K 1 1 Link to comment Share on other sites More sharing options...
Ray Davis Posted December 14, 2022 Share Posted December 14, 2022 Very good, thanks Ivan for looking that up. 👍 Link to comment Share on other sites More sharing options...
Ivan K Posted December 14, 2022 Share Posted December 14, 2022 I was wondering the same a while back because I have a retarder relay that was giving me a code, in the FRB, it is controlled by ABS ECU but I never actually found its function as we have no retarder but it does connect to Alisson ECM. Also the driveshaft would be even much shorter than it is already in our 40'. Could be doable in 45' coach. Link to comment Share on other sites More sharing options...
On_the_road Posted December 14, 2022 Author Share Posted December 14, 2022 I shot this picture while they were changing the tires. It seems that there is no retarder. Is this correct? Link to comment Share on other sites More sharing options...
Ivan K Posted December 14, 2022 Share Posted December 14, 2022 49 minutes ago, On_the_road said: I shot this picture while they were changing the tires. It seems that there is no retarder. Is this correct? Yes that is correct. Still a great 4060 tranny. 1 Link to comment Share on other sites More sharing options...
David Pratt Posted December 15, 2022 Share Posted December 15, 2022 Monaco never installed a Transmission Retarder in any of the Monaco Brand Models. I have a Transmission Retarder installed in my Foretravel ih-45. I have a lever on the drivers side console to choose up to Six Levels of braking. There is a rocker switch to turn it on just behind the lever. When turned on the Retarder will automatically be activated to what ever level you have selected by the Toggle Lever when you take your foot of the Accelerator Pedal. If you have Level 6 selected you best have your seat belt fastened tight or you might Kiss the windshield. According to Cummins and Allison you cannot have a transmission retarder and an engine brake installed together. You can have one or the other not both. I have attached a picture of the Cockpit from my ih-45. On the Drivers Side console to the left of the drivers seat you can see the lever and the rocker switch that activates the Retarder. 3 Link to comment Share on other sites More sharing options...
On_the_road Posted December 29, 2022 Author Share Posted December 29, 2022 Price drop! I have priced my Monaco Signature 45' at $79,500. Thanks for looking. Link to comment Share on other sites More sharing options...
On_the_road Posted April 12 Author Share Posted April 12 I am dropping the price to $74,900. A great Monaco, but I have to let it go. Link to comment Share on other sites More sharing options...
