Donflem Posted December 20, 2022 Share Posted December 20, 2022 MyAqua hot AHE-100-04s low tank level cut off light came on. I refilled the tank and over flow tank the red light is still on and System is not working. I was wondering if you guys have any ideas on how to reset it the manual says it resets itself but that didn’t work? Thanks Don 2007 Dynasty Link to comment Share on other sites More sharing options...
Solution Paul Busch Posted December 20, 2022 Solution Share Posted December 20, 2022 I just went through this myself. Was it low on fluid? My sensor had broken off inside the tank. Just like a toilet float. On my coach I have pull 25amp fuse and reinstall to reset. I believe you can connect both wires to check if the float is shutting down the Aqua hot. I know you can bypass the hi temp shutoff to check it Link to comment Share on other sites More sharing options...
Donflem Posted December 21, 2022 Author Share Posted December 21, 2022 Thanks Paul it was the sensor. It got down to 27 last night but the heat pump’s kept us warm till I replaced it this morning. I’m on my way to Texas for the holidays so I need the Aqua hot. Don Link to comment Share on other sites More sharing options...
Paul Busch Posted December 21, 2022 Share Posted December 21, 2022 Great, have a merry Christmas. Link to comment Share on other sites More sharing options...
96 EVO Posted December 21, 2022 Share Posted December 21, 2022 1 hour ago, Donflem said: Thanks Paul it was the sensor. It got down to 27 last night but the heat pump’s kept us warm till I replaced it this morning. I’m on my way to Texas for the holidays so I need the Aqua hot. Don You were lucky getting any heat out of your HP's at 27. Must be low humidity at your location. Link to comment Share on other sites More sharing options...
Donflem Posted December 21, 2022 Author Share Posted December 21, 2022 I know right. I was in the high desert in cali. Link to comment Share on other sites More sharing options...
