Silverleaf TM-501 UBS JIB J1708/J1939
Busnut
 Share
Go to solution Solved by On_the_road,
Hi
Just bought this silver leaf for our motorhome 2003 Monaco with ISM cummins. Any members using one or information about  recommending  a good lap top or tablet that would be a good plug and play for the silver leaf. I was thinking around an 10 inch. Also a good mount .
Thanks
  • Solution
I used an Azulle Byte Plus Mini PC with a touch screen monitor.   I shoved the PC on the floor behind the driver seat.   I mounted the display on my dash next to my GPS.   You don't need the keyboard or mouse after you set it up.   Any Windows PC can run the Silverleaf software.
I had been using a small Sony Viao laptop but it crapped out.  I replaced it with a Microsoft Surface Go 2 tablet which I got for a great price off Ebay.  I like the tablet better as it sits on my mount stand flat and doesn't interfere with line of site to the rear view mirror.
I use a floor mount stand next to the drivers side console.  I added a center support attached to the side of the console which reduces movement/vibration.  I added a dual plug 12 volt power source next to it and plug in a small inverter which powers the tablet.  I then mounted the Silverlear controller next to it.  Everything is tucked out of the way.
Edited by jacwjames
If you get a windows tablet make sure it has a full size USB port that way you will have a separate charging port. A lot of the tablets have one micro usb that is also used as the charging port so you can’t change it while the vmspc is plugged in. I had a Dell venue on my old Motorhome that worked well or Microsoft surface would work.
 Share
